Binary sensor: platform not found
Hi friend. I’m trying to set up a binary sensor but i get this error:
“Platform not found: binary_sensor.yr”
I’m trying with a simple sensor like this:
 binary_sensor:
   - platform: rpi_gpio
     ports:
     23: xxx
i have a switch rpi_gpio that works very well.
i get the same error even if instead rpi_gpio i use platform template.
It seems that my installation don’t have binary sensor component. I use hassio in the raspberry 3
If you are literally getting the text binary_sensor.yr then you have a typo or something else wrong…
I think we need to see more of your configuration.yaml file to solve this puzzle.
There’s a sensor component called “yr” but I don’t think it’s related to this issue.
yes! i’m stupid today -) :slight_smile: there was a
indentation problem that caused conflit with yr sensor (the icon of weather).
solved
Hello corrobor
could you tell me more in detail, How did you solve the prob
cause i face same error and can’t fix
Thanks in advance
  - platform: dht
    sensor: AM2302
    pin: 17
    monitored_conditions:
      - temperature
      - humidity
  - platform: filter
    entity_id: sensor.dht_sensor_temperature
    filters:
      - filter: outlier
        window_size: 2
       radius: 2.0
  - platform: filter
    entity_id: sensor.dht_sensor_humidity
    filters:
      - filter: outlier
        window_size: 2
        radius: 5.0
