Binary_sensor, value template issue
Hi, I’m new in Homeassistant,
I’m thinkig in a binary sensor to read the status of the lights from eedomuss to integrate it in lovelace,but I’m stuck with the format of value_template.
I would appreciate if someone could help me
I’m using a command_line binary sensor calling eedomus API that works as follows:
http://192.168.0.5/api/get?api_user="MYUSER"api_secret="MYLONGSECRETPWD"&action=periph.value&periph_id=123456
answer is:
{ “success”: 1, “body”:{“last_value”: 100} }
body.last_value=100 if light is on and 0 if it’s off
I’m trying 4 diferent ways but no one works
file binary_sensors.yaml
#binary_sensor:
#trial1
  - platform: command_line
    unique_id: sensordeestadodelaluzdearriba
    device_class: light
    command: >
      curl -X GET "http://192.168.0.5/api/get?api_user=xxxxxx_secret=xxxxx&action=periph.value&periph_id=1334495"
    value_template: >
      "{{value_json.body.last_value }}"
    payload_on: 100
    payload_off: 0
    scan_interval: 10
#trial2
    unique_id: sensordeestadodelaluzdearriba2
    device_class: light
    command: >
      curl -X GET "http://192.168.0.5/api/get?api_user=xxxxxx&api_secret=xxxxxx&action=periph.value&periph_id=1334495"
    value_template: >
      "{{value_json.body[0]["last_value"] }}"
    payload_on: 100
    payload_off: 0
    scan_interval: 10
#trial3
    unique_id: sensordeestadodelaluzdearriba3
    device_class: light
    command: >
      curl -X GET "http://192.168.0.5/api/get?api_user=xxxxx&api_secret=xxxxxx&action=periph.value&periph_id=1334495"
    value_template: >-
       {%- if 100 in state('value_json.body.last_value') -%}
         on
       {%- else -%}
         off
       {%- endif -%}
    #payload_on: "100"
    #payload_off: '0'
    scan_interval: '10'
#trial4
    unique_id: sensordeestadodelaluzdearriba4
    device_class: light
    command: >
    value_template: >-
       {%- if is_state('value_json.body.last_value') == 100 -%}
         on
       {%- else -%}
         off
       {%- endif -%}
    scan_interval: '10'
Isn’t it a rest sensor you need to create?
#trial5
    device_class: light
    command: >
    value_template: >
       {{ value_json.body.last_value == 100 }}
Thanks, but still not working. binary_sensor says light is off all time…
I think the issue is that I don’t really understand what does it mean
value_template: >
How is it storing the on/off state in the binary_sensor status?
It’s not storing on/off. It runs the code. If it’s true, the sensor is on, if its false the sensor is off.
Are you aware that this is a polling integration, I.e. it will only update once every 30 seconds?
Hi, to be honest I don’t know what to anwer you…
I can turn on and off lights with Homeassistant through a button in lovelace using command_line and eedomus api but I can also turn on lights with the button in the wall switch, so I need to monitor and update the status in lovelace.
I thought that with a binary sensor and shell command reading the state from the api I could update the button status with an automation
I’ve just found this error in register status
Logger: homeassistant.helpers.template
Source: helpers/template.py:575
First occurred: 16:58:00 (5 occurrences)
Last logged: 17:00:00
Error parsing value: ‘value_json’ is undefined (value: , template: {{value_json.body.last_value}})
can it be related to the name last_value from eedomus api?
best regards
Typically it means that the response is not json
Hi
Yes, I realize it has a delay time.
I think the issue is in the intrepretation of the api answer
If I check “success” the binary sensor works fine and can detect the status 1,
  value_template: >
       {{ value_json.success }}
    payload_on: 1
    payload_off: 0
but with body.last_value it doesn’t work,
 value_template: >
    {{ value_json.body.last_value }}
    payload_on: 100
    payload_off: 0
is it because value or last_value are not usable topics?
Not sure, I can say that you have too many indents for paylod_on and pay_load off. They should be in line with value_template. And your template should be indented in relation to value_template.
  value_template: >
  payload_on: 100
  payload_off: 0
