Bind Homeassistant to Wlan?
HI,
i would like to use Wlan on my RP3, how can i configure HomeAssistant that he uses
the Wlan interface instead of Ethernet?
Using WiFi is less reliable, and you’re likely to run into problems if you do that.
If you accept that, then see this guide if you’re running on Hassbian or Raspbian, and see here if you’re running Hass.io.
i have no problem to install Wlan, but how can i tell homeassistant to use it instead of Ethernet?
Easy - start by reading the links I posted
