Hi all, I'm trying to do something very basic and it is not working. I have a motion sensor (Ikea Vallhorn) and a relay that controls a light (sonoff zbminiR2). I have ZHA with a Sonoff usb dongle "E". I want the light to switch on when I am in the room.
So I wrote an automation. It works.
But now I want it to happen faster and independent from my HA instance.
So I tried to bind the switch directly to the sensor through the "manage device" GUI, selecting the binding tab on the Vallhorn, and selecting the sonoff switch as the bindable device. That seems to have worked, there was a green checkmark flash. I double checked the binding exists using ZHA toolkit, which tells me the correct clusters (endpoint 1 id 0x0006, occupancy and on/off) have been bound. The coordinator is also still bound but I want it like that. IIRC I can have the coordinator bound as well, or is that wrong?
Anyway, when I walk into the room, nothing happens. I can see the Vallhorn detects occupancy. But the switch does nothing.
I can read the zha_events from the log, and it seems that the Vallhorn sends a command immediately after it changes occupancy:
device_ieee: 5c:c7:c1:ff:fe:3e:c8:43
device_id: 647a0359a04ad6da0fcf01821a47315a
unique_id: 5c:c7:c1:ff:fe:3e:c8:43:1:0x0006
endpoint_id: 1
cluster_id: 6
command: on_with_timed_off
args:
- 0
- 200
- 0
params:
on_off_control: 0
on_time: 200
off_wait_time: 0
origin: LOCAL
time_fired: "2026-06-16T22:51:34.856305+00:00"
context:
parent_id: null
user_id: null
Can anyone give me a clue what is going wrong? zha_toolkit.binds_get on the zbminiR2 gives null, but I think that is expected?
