Hi all,
I’m seeing a new issue on my Lenovo M8 and M10 tablets running the HA Companion app. After updating to Home Assistant 2025.5+, my dashboards no longer fill the full screen. Instead, there are black bars at the top and bottom of the display. I run dashbaords in fully kiosk mode and this has been great for over a year.
- Fullscreen / immersive mode is already ON in the Companion app.
- It worked fine before (I checked an old June backup — same problem now, which points to frontend/WebView changes, not my config).
- I use kiosk-mode to hide header/sidebar.
- Issue has arisen on M10 and M8 at the same time.
Cause (I think):
- Recent HA frontend builds (2025.5+) started respecting
safe-area-inset-top/bottom. - On Lenovo M8/M10, Android System WebView reports non-zero insets for the status/nav bars.
Workarounds tested:
- Companion app fullscreen toggle → no effect.
- CSS loaded via
extra_module_url→ not applied (only JS modules load here). - Custom theme with
safe-area-inset-top/bottom: 0px→ didn’t resolve. - Fully Kiosk Browser with immersive mode → fixes the issue completely (dashboards back to true fullscreen).
- A tiny JS module injected via
extra_module_urlto override insets also works.
Ask:
- Is this new safe area behavior intentional?
- Could Companion app on tablets force
viewport-fit=coveror ignore safe area when fullscreen is enabled? - I also note the HA App is crash when reopening on teh lenovo Tablets.
Any help appreciated thanks
