Blank Text Fields When Trying to Add Integrations
Copied from issues log #92830
The problem
First time Home Assistant User and New to Ubuntu
When trying to add integrations, the text fields are blank. Where there is supposed to be text that should say “Host name”, “IP Address”, or “Port” it is blank. I tried to follow along on YouTube videos and got some integrations working but it doesn’t help for all like Ecobee.
Clicking into the text field does nothing.
Things I have tried to solve the issue with no success:
Changing languages through Profile and Settings
Tried Chrome on different machines, Safari through a iPad, Chrome and Edge
Cleared cache
Using default theme using Auto, Light and Dark modes.
Installed Ubuntu Desktop 22.04 on old desktop.
PC Specs
i3-2120
16GB RAM
128GB SSD
640GB Western Digital
2TB Hitachi
What version of Home Assistant Core has the issue?
core-2023.4.6
What type of installation are you running?
Home Assistant Core
Integration causing the issue
Ecobee, Accuweather, Samsung Smart TV
If you use Chrome - press F12. Once the side panel/pop up appears long click the refresh button and you will see 3 new options - select Empty cache and hard reload - it might help …
Thank you for the suggestion. I tried it on Win11 and Ubuntu 22.04 machines but it did not solve my problem.
Reinstalled Ubuntu 20.04 and now everything seems to be working. Possible that I messed up something during the original install.
