BLE tracker compile error
Hi, My attempt to compile example from here failed with this error.
Not sure how proceed from here?
esp32_ble_tracker:
  max_connections: 1
binary_sensor:
  - platform: ble_presence
    mac_address: 50:78:7d:15:xx:xx
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
 - framework-espidf @ 3.50402.0 (5.4.2)
 - tool-cmake @ 3.30.2
 - tool-esp-rom-elfs @ 2024.10.11
 - tool-esptoolpy @ 5.0.2
 - tool-mklittlefs @ 3.2.0
 - tool-ninja @ 1.13.1
 - tool-scons @ 4.40801.0 (4.8.1)
 - toolchain-xtensa-esp-elf @ 14.2.0+20241119
Reading CMake configuration...
-- git rev-parse returned 'fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).'
-- Building ESP-IDF components for target esp32
-- Configuring incomplete, errors occurred!
CMake Error at /data/cache/platformio/packages/framework-espidf/tools/cmake/build.cmake:620 (message):
    File "<frozen runpy>", line 189, in _run_module_as_main
    File "<frozen runpy>", line 112, in _get_module_details
    File "/root/.platformio/penv/.espidf-5.4.2/lib/python3.12/site-packages/idf_component_manager/__init__.py", line 6, in <module>
      from idf_component_tools.environment import ComponentManagerSettings
    File "/root/.platformio/penv/.espidf-5.4.2/lib/python3.12/site-packages/idf_component_tools/__init__.py", line 9, in <module>
      if ComponentManagerSettings().DEBUG_MODE:
    File "/root/.platformio/penv/.espidf-5.4.2/lib/python3.12/site-packages/pydantic_settings/main.py", line 193, in __init__
      super().__init__(
    File "/root/.platformio/penv/.espidf-5.4.2/lib/python3.12/site-packages/pydantic/main.py", line 250, in __init__
      validated_self = self.__pydantic_validator__.validate_python(data, self_instance=self)
    File "/root/.platformio/penv/.espidf-5.4.2/lib/python3.12/site-packages/idf_component_tools/environment.py", line 148, in fallback_to_default
      if field.validation_alias:
  AttributeError: 'NoneType' object has no attribute 'validation_alias'
Call Stack (most recent call first):
  /data/cache/platformio/packages/framework-espidf/tools/cmake/project.cmake:718 (idf_build_process)
  CMakeLists.txt:3 (project)
========================== [FAILED] Took 1.76 seconds ==========================
This has been a common issue recently.
Uninstall the ESPHome Builder add-on with the data clearing option enabled. Then reinstall it. You won’t lose anything.
Thank you!
This worked for me too, thanks!
