Hi everyone,
I’m trying to set up a sauna control system using the following devices:
- 1x BleBox ThermoBox:
climate.sauna1_thermobox_thermostat
(SAUNA)- Modes:
off
,heat
- Temperature range: 40–95°C
- Current temperature: 20.1°C
- Friendly name: SAUNA
- Modes:
- 2x BleBox SwitchBox DC:
switch.sauna2_switchbox_0_relay_0
(SAUNA2)switch.sauna3_switchbox_0_relay_0
(SAUNA3)
Goals:
- Modes and Relays:
- Mode 1: Turška (45–50°C): Uses ThermoBox (
). - Mode 2: Infra (45–65°C): Activates Relay 2 (
). - Mode 3: Finska (80–95°C): Activates Relay 3 (
- Functionality:
- Selecting a mode from the dropdown should:
- Activate the corresponding relay.
- Set the thermostat temperature (
) to the correct range.
- A timer should run for 1 hour after the mode starts, then turn off the sauna.
- After turning off, a cooldown timer should start before the system can be reactivated.
Issue:
I’m using Home Assistant and struggling to:
- Get the input select menu to control the relays and thermostat.
- Implement timers for the active and cooldown phases.
Each relay works fine when controlled directly, but the automation doesn’t function as intended with the mode selector.
Request:
I’d appreciate any guidance or examples for:
- Automations for mode selection and relay control.
- Timer implementation for the active and cooldown phases.
Thanks in advance for any help!
