Blind control - advanced - with position control
Hello everyone,
I would like to change my blind control.
At the moment I have set this up time-controlled with NodeRed, whereby I have created helpers with times that are queried once a day.
This works very well, but I will now switch this to the HA automation, because I use NR too little to have to deal with it again and again.
In this context, I would like to incorporate a position control for the blinds.
Do I also have to create this using helpers by, for example, specifying the position in % (e.g. 60% closed) or is there a way to further automate this?
Local weather report with hours of sunshine (in summer) ā€“ would be the best solution if it is reasonably reliable.
Light sensor ā€“ which is queried every 3 hours between 10 am and 6 pm, for example.
Important ā€“ I would like to change the blind state a maximum of 2-3 times
Iā€™m grateful for any approach.
The weather data would have to be available for Germany!
