Blinds and Lovelace Tuya Integration
I have an odd problem. I have several sets of motorised blinds and when added to lovelace using the “add to dashboard” button it creates several buttons.
Blind. Open, Stop, Close.
They are all reversed in function so when I click Blind, and pull the blind up, it closes.
The other buttons dont do anything because they are reversed.
Is there a way to fix this? Setting the motor direction to back doesnt fix it.
I’ve just tried this and it isnt working for me but its probably a configuration issue.
My blind is: entity: cover.living_room_window_curtain
I tried changing the names and restarting the yaml but it did not work for me.
The controls showed but did not move the blind.
Do I have to create an entry for each blind? or does the template change all of them?
Do i have to create an inverted version for each blind entity
I found it easier to use the mushroom card and set it to horizontal layout, and position control.
