I know the Espurna firmware have an option, and Tasmota almost certainly have it too, to prevent both relay from being activated at the same time.
Ok thanks, i flash now the sonoff (the problem is RX-TX , i donât know why )
now i search this option⌠thank you very much !
I think the option is in the firmware code and not on the web UI, so you must first look for it in the code before uploading it.
OH⌠OK
Maybe i need some helps, i search on Google, because i want a button, maybe is a good idea donât use a switch ON/OFF, but a button with âif you touch the button One: the blinds go up , button two, go downâ , but only if you hold down the buttons, no?
Take a look at this thread:
Does your blinds have limit switches?
Thanks, i have limit switches. In the sonoffâs webpage i donât see the âRolling Shutterâ option, maybe now it has anothe name, i search this, anyway⌠this post seems like very interesting for my case.
Thank you very much.
Hello mate, perhaps take a look at this thread:
Itâs now working fine for me, i even use automations with timers to open/close fully (without the need to âstopâ it manually).
