Blink camera snapshot
I have tried to run an automation to take a snapshot from my blink camera and send it to my phone when someone presses the doorbell. It is working but I think the issue I am having is the camera is already activated with motion so when the trigger camera action fires it is delayed so the photo I get misses the person as they have left already. Any suggestions on getting the image at the time the button is pressed or as close to ?
Are you sure that is really the issue?
That would be a very long delay.
Share your automation yaml.
I think so, here you go
alias: Doorbell Activated
description: Triggers Blink cameras, takes snapshots, and sends them to Kevin via Telegram.
triggers:
  - entity_id: input_boolean.doorbell_press
    to: "on"
    trigger: state
conditions: []
actions:
  - variables:
      frontdoor_file: >-
        /config/blinkcameras/images/frontdoor_{{ now().strftime('%Y%m%d_%H%M%S')
      frontdoorview_file: >-
        /config/blinkcameras/images/frontdoorview_{{
  - target:
      entity_id: camera.front_door
    action: blink.trigger_camera
  - target:
      entity_id: camera.front_door_view
  - delay:
      seconds: 2
  - data:
      filename: "{{ frontdoor_file }}"
    action: camera.snapshot
  - data:
      filename: "{{ frontdoorview_file }}"
  - data:
      target: xxxxxxx
      file: "{{ frontdoor_file }}"
      caption: Front Door Camera
    action: telegram_bot.send_photo
  - data:
      target: xxxxxxx
      file: "{{ frontdoorview_file }}"
      caption: Front Door View
  - target:
    action: input_boolean.turn_off
mode: single
https://community.home-assistant.io/t/how-to-help-us-help-you-or-how-to-ask-a-good-question/114371#oneone-format-it-properly-16
Thanks Tom, hopefully that is correctly posted now.
What happens if you try the camera.snapshot action instead?
I will try that tomorrow when the house is awake :grinning:
That doesn’t work. The snapshot sends the last image rather than a current view. The trigger action refreshes the image.
Any other thoughts or suggestions?
No sorry. I don’t know anything about Blink cameras. It seems they do not behave like other cameras behave in HA.
