Blink Component Error after Python 3.6 upgrade
I’ve recently upgraded my home assistant to python 3.6 (I’m using HA v0.55.0 with AIO install on raspbian). Ever since the upgrade I’ve started getting this error with my blink component:
2017-10-16 21:34:06 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-10-16 21:34:08 WARNING (MainThread) [homeassistant.setup] Setup of blink is taking over 10 seconds.
2017-10-16 21:34:08 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform yr is taking over 10 seconds.
2017-10-16 21:34:08 WARNING (MainThread) [homeassistant.components.sensor.yr] Retrying in 15 minutes:
2017-10-16 21:34:18 ERROR (MainThread) [homeassistant.setup] Error during setup of component blink
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/packages/urllib3/connection.py", line 141, in _new_conn
    (self.host, self.port), self.timeout, **extra_kw)
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/packages/urllib3/util/connection.py", line 60, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "/usr/local/lib/python3.6/socket.py", line 743, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py", line 600, in urlopen
    chunked=chunked)
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py", line 345, in _make_request
    self._validate_conn(conn)
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py", line 844, in _validate_conn
    conn.connect()
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/packages/urllib3/connection.py", line 284, in connect
    conn = self._new_conn()
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/packages/urllib3/connection.py", line 150, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x68b54970>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/adapters.py", line 438, in send
    timeout=timeout
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py", line 649, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/packages/urllib3/util/retry.py", line 388, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
requests.packages.urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='prod.immedia-semi.com', port=443): Max retries exceeded with url: /login (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x68b54970>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/setup.py", line 194, in _async_setup_component
    component.setup, hass, processed_config)
  File "/usr/local/lib/python3.6/asyncio/futures.py", line 331, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/local/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
    future.result()
  File "/usr/local/lib/python3.6/asyncio/futures.py", line 244, in result
    raise self._exception
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 55, in run
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/blink.py", line 56, in setup
    hass.data[DOMAIN] = BlinkSystem(config)
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/blink.py", line 51, in __init__
    self.blink.setup_system()
  File "/srv/homeassistant/lib/python3.6/site-packages/blinkpy.py", line 312, in setup_system
    self.get_auth_token()
  File "/srv/homeassistant/lib/python3.6/site-packages/blinkpy.py", line 337, in get_auth_token
    data=data, json_resp=False, reqtype='post')
  File "/srv/homeassistant/lib/python3.6/site-packages/blinkpy.py", line 37, in _request
    data=data)
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/api.py", line 112, in post
    return request('post', url, data=data, json=json, **kwargs)
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/api.py", line 58, in request
    return session.request(method=method, url=url, **kwargs)
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/sessions.py", line 518, in request
    resp = self.send(prep, **send_kwargs)
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/sessions.py", line 639, in send
    r = adapter.send(request, **kwargs)
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/adapters.py", line 502, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='prod.immedia-semi.com', port=443): Max retries exceeded with url: /login (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x68b54970>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
2017-10-16 21:34:43 WARNING (MainThread) [homeassistant.components.media_player] Setup of platform cast is taking over 10 seconds.
2017-10-16 21:36:16 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from netgear took longer than the scheduled scan interval 0:00:12
2017-10-16 21:44:04 ERROR (SyncWorker_3) [pynetgear] Error talking to API
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/packages/urllib3/util/connection.py", line 83, in create_connection
    raise err
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/packages/urllib3/util/connection.py", line 73, in create_connection
    sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
    chunked=chunked)
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py", line 356, in _make_request
    conn.request(method, url, **httplib_request_kw)
  File "/usr/local/lib/python3.6/http/client.py", line 1239, in request
    self._send_request(method, url, body, headers, encode_chunked)
  File "/usr/local/lib/python3.6/http/client.py", line 1285, in _send_request
    self.endheaders(body, encode_chunked=encode_chunked)
  File "/usr/local/lib/python3.6/http/client.py", line 1234, in endheaders
    self._send_output(message_body, encode_chunked=encode_chunked)
  File "/usr/local/lib/python3.6/http/client.py", line 1026, in _send_output
    self.send(msg)
  File "/usr/local/lib/python3.6/http/client.py", line 964, in send
    self.connect()
  File "/srv/homeassistant/lib/python3.6/site-packages/requests/packages/urllib3/connection.py", line 166, in connect
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.HTTPConnection object at 0x67adc850>: Failed to establish a new connection: [Errno 111] Connection refused
    timeout=timeout
requests.packages.urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.1.1', port=80): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x67adc850>: Failed to establish a new connection: [Errno 111] Connection refused',))
  File "/srv/homeassistant/lib/python3.6/site-packages/pynetgear/__init__.py", line 113, in _make_request
    self.soap_url, headers=headers, data=message, timeout=10)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.1.1', port=80): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x67adc850>: Failed to establish a new connection: [Errno 111] Connection refused',))
2017-10-16 21:44:04 WARNING (SyncWorker_3) [homeassistant.components.device_tracker.netgear] Error scanning devices
2017-10-16 21:59:27 ERROR (SyncWorker_9) [pynetgear] Error talking to API
    raise err
    sock.connect(sa)
    chunked=chunked)
    self.send(msg)
    self.connect()
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.HTTPConnection object at 0x639a4e50>: Failed to establish a new connection: [Errno 111] Connection refused
    timeout=timeout
requests.packages.urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.1.1', port=80): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x639a4e50>: Failed to establish a new connection: [Errno 111] Connection refused',))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.1.1', port=80): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x639a4e50>: Failed to establish a new connection: [Errno 111] Connection refused',))
2017-10-16 21:59:27 WARNING (SyncWorker_9) [homeassistant.components.device_tracker.netgear] Error scanning devices
2017-10-16 22:14:50 ERROR (SyncWorker_15) [pynetgear] Error talking to API
    raise err
    sock.connect(sa)
    chunked=chunked)
    self.send(msg)
    self.connect()
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.HTTPConnection object at 0x618de290>: Failed to establish a new connection: [Errno 111] Connection refused
    timeout=timeout
requests.packages.urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.1.1', port=80): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x618de290>: Failed to establish a new connection: [Errno 111] Connection refused',))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.1.1', port=80): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x618de290>: Failed to establish a new connection: [Errno 111] Connection refused',))
2017-10-16 22:14:50 WARNING (SyncWorker_15) [homeassistant.components.device_tracker.netgear] Error scanning devices
2017-10-16 22:45:36 ERROR (SyncWorker_11) [pynetgear] Error talking to API
    raise err
    sock.connect(sa)
Any suggestions on how to resolve this would be much appreciated.
Thanks,
Tony
