Blink Integration Scripts for dummies
Hi I am using the blink integration. But I can’t get the scripts working.
Here is what I did:
-First I allowed the /tmp folder in the configuration.yml
homeassistant:
  allowlist_external_dirs:
    - "/tmp"
-Restart Home Assistant
-tmp folder exists (checked in the terminal)
[core-ssh ~]$ ls -la /tmp/
total 16
drwxrwxrwt    1 root     root          4096 Jul 26 16:35 .
drwxr-xr-x    1 root     root          4096 Jul 24 15:14 ..
drwxr-xr-x    2 root     root          4096 Jul 24 15:15 .bashio
drwx------    2 root     root          4096 Jul 24 17:44 tmux-0
[core-ssh ~]$
Settings → Automation & Scenes → Scripts → Add Script → Create New Script → Edit in YML
Pasted this:
alias: "Blink Snap Picture"
sequence:
  - service: blink.trigger_camera
      entity_id: camera.blink_my_camera
  - delay: 00:00:05
  - service: blink.blink_update
  - service: camera.snapshot
      filename: /tmp/my_image.jpg
I tried it like this and also changed it to this because my camera is called Garage in the App.
alias: Blink Snap Picture
sequence:
    data: {}
      entity_id: camera.garage
  - delay: "00:00:05"
    data: {}
      entity_id:
        - camera.garage
I don’t get any file in the /tmp directory.
I also added multiple cameras to the script like this:
sequence:
    data: {}
      entity_id:
        - camera.garage
        - camera.haus
        - camera.nebengebaude
  - delay: "00:00:05"
    data: {}
      entity_id:
        - camera.garage
        - camera.haus
also no success.
I also tried another script which I want to use:
- id: save_blink_video_on_motion
  alias: "Save Blink Video on Motion"
    platform: state
    entity_id: binary_sensor.blink_my_camera_motion_detected
    to: "on"
    service: blink.save_video
      filename: "/tmp/videos/blink_video_{{ now().strftime('%Y%m%d_%H%M%S') }}.mp4"
Here I get the message when I want to save the script:
Message malformed: expected a dictionary
Can anyone explain me how to use this integration and what I am doing wrong here.
I am using a Sync Module 2 and 3 x Blink Mini Cameras.
:thinking:
filename: /config/tmp/..........
yes this helped now I get the file.
Is it possible to have one script and use 3 cameras in it and save a file for each camera with the camera name. I am not sure of the syntax but something like this.
sequence:
    data: {}
      entity_id:
        - camera.garage
        - camera.haus
  - delay: "00:00:05"
    data: {}
      entity_id:
        - camera.garage
        - camera.haus
      filename: >-
        /config/tmp/blink_image_{"target.${entity.id}}_{{now().strftime('%Y%m%d_%H%M%S')}}.jpg
How can I put the snapshot later to the dashboard ?
your step by step explanation really helped me a lot!
(Even though it was actually meant as a question)
I don’t understand why the instructions on “Blink - Home Assistant” etc. are not formulated so clearly…
did you find a solution to show the updated pictrure in lovelace?
no not yet :frowning:
