Blog about adding 433 MHz devices to your Home-Assistant
the other day I wrote a blog about adding the external sensor of some cheap weatherstation from Aldi to Home-Assistant. Honestly, there are better sensors available, but playing with an RTL-SDR stick, the rtl_433 addon was still nice.
The only drawback for most of you is that I wrote this blog in german — but there are browser plugins (I suggest the one from DeepL, they translate much better than Google Translate) to have things accessible for you.
So, we have these topics covered in the two blog posts:
  • the two devices, batteries needed, rought prices
  • routing a USB device via Proxmoxx into the Home-Assistant VM
  • using rtl_433 addon
  • short intro to MQTT Explorer so that you can see what 433 MHz devices you received
  • documentation about how to (intentionally!) manually import some of the found devices as entities into Home-Assistant (there is some auto-import available, but that installs way too many device into HA. Like the tire-pressure sensor of a random car passing your house …)
And since a humidity sensor broke, there is one addon:
  • how to replace a hardware outdoor sensor with a template helper that gets the humidity
    from your weather integration
