Sorry, my comment was misleading: I am using chlorine tablet (slow chlorine) for pool disinfection and I am noticing big variations of ORP. The tablet slowly dissolve during 1 week. What I was mentioning is that I did not added or removed chlorine tablet during the time shown in the graph with ORP. I wonder of there is a problem with my Blue Connect or what I am observing is normal
FYI:
For me, the values calculated by esp match pretty close the values in the app using this formula for ORP:
float orp = (float)( (int16_t) (x[6]<< 8) + x[5]) / 4.0;
I see some of you use:
float orp = (float)( (int16_t) (x[6]<< 8) + x[5]) / 3.86 ;
Maybe this because of Blue Connect ācalibrationā?
Also: My device is ānewā and the battery calculated by esp is ~30. Are we correctly interpreting the battery information?
I think this is normal. Iām also using the same kind of chlorine tables, and my ORP levels fluctuate within about 100mV throughout the day. As far as I can see, it goes down at night and increases during the day, perhaps itās activated by sunlight?
My guess is that its normal as well.
same as with Nick
I calibrated my unit with a kit and then took 7 readings spread over a few days and added them to a script. The outcome was that when using the 3.86 the results were closer to the APP values.
The battery is a guess, at least at my end and what I got from the forum. MY unit is 1 .5 season in service, no idea what the real level is and if that value is actually the battery level.didnt take my battery out to check (to be honest)
When your unit is new it should be close to 3.8 - 4.1V (is that 38 - 41 in esp?). To be sure you could take it out put it on a volt meter and see the real value. Then we can modify the calculation to match
I set up MQTT Server, MQTT Broker Addon in HomeAssistant and could get some positive results with test subscriptions and publications (by command line and from within the MQTT Addon in HomeAssistant, too - no problems, communication and messaging seem to work).
Set up Proxy App of @LordMike and in my HomeAssistant Instance, there are popping up some things; my Pool is definitely found, but I do not get any sensors for PH, ORP, Temperature and so on.
All components are running in separate Docker Containers:
Mosquitto, Mikeās Proxy App as well as the HomeAssistance Instance itself. All of them with docker-compose. All of them at the same physical machine (Pi 4).
From within HomeAssistant, within MQTT Integration, I set Server IP 127.0.0.1 (Mosquitto Docker is running at the same machine). I was able to successfully make a subscription which reacted on an adequate public.
As MQTT-Server Property in Mikeās Proxy App I set 127.0.0.1, too, and network_mode, I set to host (same machine here, too).
In none of the logs I can see any errorā¦
Whatās going wrong? Or what has been overseen by me to get the measurings?
Strange thingā¦ Some minutes ago, I took a look at my HomeAssistant Overview for a completely other reason and suddenly, it shows the sensors with the pool measurements . Dunno why I didnāt see them after having set up Mikeās proxy app, but now, theyāre there. So no further help needed.
Now, next step for me is to get running JosĆ©ās python code for Bluetooth reading. I would like to get this connected the way that I can do on-demand bluetooth readings no matter, where I am. I still have the very very old Blue Connect Version with 2 daily automatic measurings for free without any subscription. Most time, it works well, but sometimes, I do not get any updated measurements via SigFox for some days. This very rarely occurs, but anyway, in this case, it would be helpful for me to have a possibility to enforce a āremoteā bluetooth reading. Maybe, some time regularly, if SigFox really died.
Good you got it to work. If your device is doing readings, itās entirely possible it does then 20 times a day, but BR will only āreleaseā new readings twice a day.
I believe I made a function / command you can call to release the latest data that BR has received. Play with it and see what you can get.
Iāve not done any automation here as it is in the grey area.
Thank you for your reply. Two readings a day are fully enough for me.
You mean that automatically, your proxy app will fetch these 2 readings, but that I may be able to even get up to 20 by means of your tool?
Just to make sure that I correctly understand youā¦
Yes.
As Iāve understood it, BR have a setup where data may come in at any time from automated means, like wifi (Bluetooth gateway) or sigfox. But depending on your license, they will not store that data for you unless you request it.
As an example. With the wifi gateway. If you do a new reading of the sensor, the data may be up to an hour old. This, and given the name of the api called when you ādo a readingā, I imagine the sensor will send out readings often - but BR wonāt store them.
What you can do then is automatically call āget a new readingā to ensure they store the new resdings. Itās entirely possible that the older sensors also push out readings 20 times a day, but BR wonāt store 18 of them. Itās also possible they do 2 - who knows
Mike.
Hi all, first of all, many thanks to the people who worked on the YAML script from @nheinemans.
I configured my ESP and mainly only at the MAC address from my BR, and it immediately started to retrieve my values. Iām really happy with it so far! However, I noticed some differences in the ORP values between the App (sigfox) and the BT measurements. Could this be caused by the ādelayā in the measurements? The strange thing is that over BT, it indicates the highest measurement from last night as 798mV, but in the app, it shows the highest point at 772mV.
Unfortunately, as I have seen so far, all the advices for Bluetooth readings are very ESP-specific. If thereās only a Raspberry Pi 4 with integrated Bluetooth module (and no extra ESP Module) - is there already any way to make HA trigger bluetooth readings?
What Iāve already done so far, is to set up MQTT Server and Broker as well as Mikeās proxy app what finally led me to have integrated all the information to HA. Whatās missing to me, is being able to sync via Bluetooth.
I have been using the BT via ESPHome for almost a week now, and what I did notice is that the value I am getting via the BT proxy is about +/- 20mV higher than what the app is showing.
I did several manual measurements, first over the ESP BTproxy and directly after that over the BT in the BlueRiiot app. I took the average difference between them and put it in the float, in my case it whas minus 21.57826
float orp = (float)((int16_t)(x[6]<< 8) + x[5]) / 3.86 - 21.57826;
First of all, thanks to anyone that has contributed. AS @robertjan, I too have to subtract the same amount to get a correct measurement for ORP.
Plus, Iāve transformed the battery voltage to a percentage (the new one is 3.6v):
float bat = (float)( (int16_t) x[11]) / 36 * 100;
and added a restart switch.
My complete setup is here: esphome-contrib/blueconnect.yaml at main Ā· dbochicchio/esphome-contrib (github.com)
Iāve also added the secrets in the readme, for anyone wanting a smoother start.
Just moved my config over to this, thank you!
One question, my battery is reporting as 0. Logs below. However Iām guessing itās not 0 otherwise I wouldnāt be getting a response. Any suggestions?
[20:59:12][V][sensor:043]: 'pooltest Battery': Received new state 0.000000
[20:59:12][D][sensor:094]: 'pooltest Battery': Sending state 0.00000 % with 0 decimals of accuracy
Remove the / 36 * 100 part and try to post the value. It could be decoded different, idk. From this thread, my impression is that different firmware may have different results.
Iāve edited the yaml so the battery looks like this:
float bat = (float)( (int16_t) x[11]);
ESP_LOGD("bat", "%f", bat);
id(sensor_${blueriiot_id_prefix}_bat).publish_state(bat);
Unfortunately, the battery is still reporting 0%, logs are:
[14:58:33][D][bat:171]: 0.000000
[14:58:33][V][sensor:043]: 'pooltest Battery': Received new state 0.000000
[14:58:33][D][sensor:094]: 'pooltest Battery': Sending state 0.00000 % with 0 decimals of accuracy
With my very limited knowledge it looks like the device is reporting 0%, so a device issue rather than esphome issue?
Try to post the raw values, so other may look for it and give further advices.
I have installed the esphome based solution from jose, but the esp is not connecting, i am not getting any data. Is there a good idea, how to debug it, in the logs of the esp i see not a single debug info? Any tip is welcome.
This is my code (also parts for my apple watch inside)
substitutions:
# name: atom-lite-1-de0ce8
roomname: Wohnzimmer
staticip: 192.168.1.145
yourname: Lukas
rssi_present: id(harssi_present).state
rssi_not_present: id(harssi_not_present).state
rssi_timeout: id(harssi_timeout).state
# erster Blueconnect
blueriiot1_mac: '00:A0:50:C7:46:XX'
blueriiot1_name_prefix: 'whirlpool'
blueriiot1_id_prefix: 'pl'
# send true 0x01 to this service ID
blueriiot_send_service_uuid: 'F3300001-F0A2-9B06-0C59-1BC4763B5C00'
blueriiot_send_characteristic_uuid: 'F3300002-F0A2-9B06-0C59-1BC4763B5C00'
# notification is recieved on this Service ID
blueriiot_recieve_service_uuid: 'F3300001-F0A2-9B06-0C59-1BC4763B5C00'
blueriiot_recieve_characteristic_uuid: 'F3300003-F0A2-9B06-0C59-1BC4763B5C00'
esphome:
name_add_mac_suffix: True
platformio_options:
build_flags:
- -Wno-maybe-uninitialized
packages:
esphome.bluetooth-proxy: github://esphome/bluetooth-proxies/m5stack-atom-lite.yaml@main
esp32:
board: m5stack-atom
framework:
# type: arduino
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
password: ""
ota:
password: ""
wifi:
ssid: !secret wifi_ssid
manual_ip:
# Set this to the IP of the ESP
static_ip: $staticip
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.1.3
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
ap:
ssid: "Atom-Lite-1 Fallback Hotspot"
password: "xx"
#captive_portal:
bluetooth_proxy:
active: true
#web_server:
# port: 80
# auth:
# username: admin
# password: Quatschkopf01
esp32_ble_tracker:
scan_parameters:
interval: 300ms
window: 50ms
active: true
on_ble_advertise:
- then:
# Look for manufacturer data of form: 4c00 10 05 YY 98 XXXXXX
# Where YY can be 01..0F or 20..2F; and XXXXXX is ignored
- lambda: |-
optional<int16_t> best_rssi = nullopt;
for (auto data : x.get_manufacturer_datas()) {
const int16_t device_rssi = x.get_rssi();
// ESP_LOGD("ble_adv", "Found Device (mac %s) rssi %i", x.address_str().c_str(), device_rssi);
// Guard against non-Apple datagrams, or those that are too small.
if (data.data.size() < 4 || data.uuid.to_string() != "0x004C" || data.data[0] != 0x10 || data.data[1] < 5) {
// ESP_LOGD("ble_adv", "Non Apple datagrams found, skipping, uuid=%s, data.data.size()=%i, data.data[0]=%i, data.data[1]=%i",data.uuid.to_string().c_str(),data.data.size(),data.data[0],data.data[1]);
continue;
const int16_t rssi = x.get_rssi();
const uint8_t status_flags = data.data[2] >> 4; // High nibble
const uint8_t data_flags = data.data[3];
// ESP_LOGD("ble_adv", "status_flags=%i, data_flags=%i",status_flags,data_flags);
if (data_flags == 0x98 || data_flags == 0x18) { // Match unlocked Apple Watch. To also match locked watch use: if (data_flags == 0x98 || data_flags == 0x18) {
if (status_flags == 0 || status_flags == 2) {
best_rssi = max(rssi, best_rssi.value_or(rssi));
ESP_LOGD("ble_adv", "Found Apple Watch (mac %s) rssi %i", x.address_str().c_str(), rssi);
} else {
ESP_LOGD("ble_adv", "Possible Apple Watch? (mac %s) rssi %i, unrecognised status/action flags %#04x", x.address_str().c_str(), rssi, data.data[2]);
if (best_rssi) {
ESP_LOGD("ble_adv", "Publish State of Apple Watch (mac %s)", x.address_str().c_str());
id(apple_watch_rssi).publish_state(*best_rssi);
//else {
// ESP_LOGD("ble_adv", "Not publishing State of Apple Watch (mac %s)", x.address_str().c_str());
ble_client:
# erster Sensor
- mac_address: ${blueriiot1_mac}
on_connect:
then:
- lambda: "id(binary_sensor_${blueriiot1_id_prefix}_connected).publish_state(true);"
- delay: 2s
- button.press: button_${blueriiot1_id_prefix}_doreading
on_disconnect: [lambda: "id(binary_sensor_${blueriiot1_id_prefix}_connected).publish_state(false);"]
switch:
# erster Sensor
- platform: ble_client
ble_client_id: ble_client_${blueriiot1_id_prefix}
restore_mode: ALWAYS_OFF
globals:
- id: timeout
type: int
restore_value: no
initial_value: '30000'
# erster Sensor
name: ${blueriiot1_name_prefix} Temperature
# Optional variables:
unit_of_measurement: "Ā°C"
icon: "mdi:water-percent"
device_class: "temperature"
state_class: "measurement"
accuracy_decimals: 1
#unit_of_measurement: "Ā°C"
#icon: "mdi:water-percent"
#device_class: "temperature"
device_class: "voltage"
device_class: "battery"
name: "$yourname Apple Watch $roomname RSSI"
device_class: signal_strength
unit_of_measurement: dBm
accuracy_decimals: 0
filters:
- exponential_moving_average:
alpha: 0.3
send_every: 1
on_value:
then:
- lambda: |-
if (id(apple_watch_rssi).state > $rssi_present) {
id(room_presence_debounce).publish_state(1);
ESP_LOGD("sensor_value", "Detected Apple Watch (rssi %i)", (int)id(apple_watch_rssi).state);
} else if (id(apple_watch_rssi).state < $rssi_not_present) {
id(room_presence_debounce).publish_state(0);
ESP_LOGD("sensor_value", "Lost Apple Watch (rssi %i)", (int)id(apple_watch_rssi).state);
- script.execute: presence_timeout # Publish 0 if no rssi received
filters:
- sliding_window_moving_average:
window_size: 3
send_every: 1
- platform: homeassistant
name: HA RSSI Present Value
entity_id: input_number.rssi_present_$roomname
internal: true
name: HA RSSI Not Present Value
entity_id: input_number.rssi_not_present_$roomname
internal: true
name: HA RSSI Timeout Value
entity_id: input_number.rssi_timeout_$roomname
internal: true
accuracy_decimals: 2
on_value:
- globals.set:
value: !lambda 'return id(harssi_timeout).state * 1000;'
binary_sensor:
# erster Sensor
device_class: connectivity
entity_category: diagnostic
name: "$yourname $roomname presence"
device_class: occupancy
lambda: |-
if (id(room_presence_debounce).state > 0.99) {
return true;
} else if (id(room_presence_debounce).state < 0.01) {
return false;
} else {
return id(room_presence).state;
script:
# Publish event every 30 seconds when no rssi received
mode: restart
then:
- delay: !lambda 'return id(timeout);'
- lambda: |-
button:
name: ${blueriiot1_name_prefix} do reading
internal: true
on_press:
then:
- ble_client.ble_write:
service_uuid: ${blueriiot_send_service_uuid}
characteristic_uuid: ${blueriiot_send_characteristic_uuid}
# A lambda returning an std::vector<uint8_t>.
value: !lambda |-
return {0x01};
- platform: restart
name: "$yourname $roomname restart"
text_sensor:
# erster Sensor
name: ${blueriiot1_name_prefix} reading data
internal: true
service_uuid: ${blueriiot_recieve_service_uuid}
characteristic_uuid: ${blueriiot_recieve_characteristic_uuid}
notify: true
update_interval: never
on_notify:
then:
lambda: |-
std::string rawhex = format_hex_pretty((uint8_t *) x.c_str(), x.size()).c_str();
ESP_LOGD("raw_hex", "%s", rawhex.c_str());
float temperature = (float)((int16_t)(x[2]<< 8) + x[1])/100;
ESP_LOGD("temp", "%f", temperature);
id(sensor_${blueriiot1_id_prefix}_temperature).publish_state(temperature);
float raw_ph = (float)( (int16_t) (x[4]<< 8) + x[3]) ;
float ph = (float)( (int16_t) (2048 - raw_ph)) / 232 + 7 ;
ESP_LOGD("ph", "%f", ph);
id(sensor_${blueriiot1_id_prefix}_ph).publish_state(ph);
ESP_LOGD("orp", "%f", orp);
id(sensor_${blueriiot1_id_prefix}_orp).publish_state(orp);
float bat = (float)( (int16_t) x[11]) ;
id(sensor_${blueriiot1_id_prefix}_bat).publish_state(bat);
id(switch_${blueriiot1_id_prefix}_enable).turn_off();
# ENDE erster Sensor
Lukas
