Blue Iris integration with Home Assistant
I have home assistant running on a Pi on on wi-fi with only a couple different integrations. Now I want to add some security cameras using bule iris. But I would like to create the ground work before I start any of this and I have some questions. I would like to install and run Blue Iris from a PC that is also on my wireless network So my question is, can I install BOTH hard wired and wifi cameras and have both of them show up in Blue Iris and hence available in home assistant? My hard wired lan(192.168.0.1) is a different domain than my wireless(192.168.1.1). Will this be possible, becuase I do not want to limit myself to having wireless cameras.
You’ll need the two different subnets to be able to talk. Otherwise it should be nothing special.
