[Blueprint] Auto Resolve “Heat/Cool” Mode by Season – for A/C Units Without Remote Control
When an A/C unit (or any climate entity) switches itself into "heat_cool" mode, this blueprint automatically sets it to heat in colder months and cool in warmer months - and applies your preferred target temperatures.
Tested on Daikin A/C with Faikin controller, but it should work with any climate device that exposes the climate.* entity and supports the heat_cool mode.
Why I Created This
We currently don’t have remotes for our A/C units, so we’re turning them on using the physical buttons on the indoor units.
When pressed, the unit always starts in "heat_cool" mode with a fixed 25 °C setpoint, which isn’t ideal - I prefer different setpoint.
To automate this, I created this blueprint to automatically:
- Detect when the unit switches to
"heat_cool", - Resolve it into heat or cool depending on the season (Central Europe),
- And apply my preferred temperature for each mode.
Now, the A/C starts correctly every time, even when controlled manually by the button on the unit itself.
What It Does
- Watches selected
climate.*entities - When any changes to
"heat_cool", automatically:- Determines the season (Central European months)
- Switches the mode to:
- HEAT from September → April
- COOL from May → August
- Sets the target temperature according to your per-entity settings or defaults
- Optional: only trigger when the setpoint is near 25 °C (so it won’t react to other mode changes)
- Fully configurable per A/C unit
Inputs
| Input | Description | Default |
| Climate Entities | Climate entities to monitor | — |
| Only React When Setpoint Matches | Optional check for ~25 °C trigger | Off |
| Setpoint Match Value | Target temperature to match (±0.6 °C) | 25 |
| Per-Entity Setpoints | Optional map of each entity with heat/cool temps | heat = 21, cool = 25 |
Seasonal Behavior
- Cold months (Sep–Apr) → switches to heat
- Warm months (May–Aug) → switches to cool
You can easily adjust the month lists inside the YAML if you live in a different region.
Import the Blueprint
Example Use Case
- Daikin A/C (Faikin integration) - tested and working perfectly
- Other brands - should also work as long as the integration uses standard HA
climate.*attributes - Useful for any climate device that defaults to
heat_coolwhen powered on and doesn’t let you change the default setpoint
Notes
- Works with multiple A/C units at once
- If you don’t define per-entity setpoints, defaults of 21 °C (heat) and 25 °C (cool) are used
- Designed around Central European seasons, but logic is easily editable
If you try it on another brand or climate integration, please share your results or improvements.
