Lutron Sunnata Keypad Combination Lock
Home Assistant Blueprint for using a Lutron Sunnata RadioRA3 keypad as a “combination lock”, where an event is triggered after a specific sequence of button presses (single click, double click, or long press) is detected.
Goals
- Enable secure or hidden functionality (unlocking doors, disarming alarms, etc.) by requiring a specific button sequence
- Support complex passcode patterns mixing single clicks, double clicks, and long presses
Usage
The Lutron Sunnata Keypad Combination Lock blueprint monitors button events and tracks a sequence of actions. When the sequence matches your configured passcode, it triggers your chosen action.
Important
Button release events are only fired when the button is configured as Single Action in the Lutron designer software. This means the combination lock will not work correctly for buttons configured as Scene Toggle or Zone Toggle.
- Install the Lutron Sunnata Keypad Combination Lock blueprint using the badge above.
- In the Lutron Designer software, set the buttons you want to use to Single Action.
- Create two helper entities (see Installation):
- An
input_texthelper to store the in-progress passcode - An
input_datetimehelper (with time enabled) to track the last button press
- Create a Lutron Sunnata Keypad Combination Lock automation, defining your passcode sequence and the action to trigger when matched.
Supported Devices
- RRST-W2B-XX (Sunnata 2-Button Keypad)
- RRST-HN2B-XX (Sunnata Hybrid 2-Button Keypad)
- RRST-W3RL-XX (Sunnata 3-Button Keypad with Raise/Lower)
- RRST-HN3RL-XX (Sunnata Hybrid 3-Button Keypad with Raise/Lower)
- RRST-W4B-XX (Sunnata 4-Button Keypad)
- RRST-HN4B-XX (Sunnata Hybrid 4-Button Keypad)
Requirements
- Home Assistant 2024.6 or newer
- Lutron Caseta integration configured
- At least one Sunnata keypad connected to your Lutron controller
- Two helper entities (see Installation section)
Installation
Option 1: Direct Import (Recommended)
Click the badge above or use this link in Home Assistant:
Settings → Automations & Scenes → Blueprints → Import Blueprint
Then paste the raw GitHub URL:
https://github.com/bengber/home-assistant-lutron-sunnata-blueprints/blob/main/blueprints/automation/lutron-sunnata-keypad-combination-lock.yaml
Option 2: Manual Installation
- Download the
lutron-sunnata-keypad-combination-lock.yamlfile - Copy it to your Home Assistant
config/blueprints/automation/directory - Restart Home Assistant or reload automations
Creating Required Helper Entities
Before creating an automation, you need to create two helper entities:
- Input Text Helper (for passcode progress):
Settings → Devices & Services → Helpers → Create Helper → Text
Name: "Keypad Passcode Progress"
Max length: 255
- Input Datetime Helper (for last press time):
Settings → Devices & Services → Helpers → Create Helper → Date and/or time
Name: "Keypad Last Press Time"
✓ Date
✓ Time
Configuration Options
Passcode Sequence
Define your passcode as a comma-separated list of button actions. Each action should be one of:
button_1_single_click,button_1_double_click,button_1_long_pressbutton_2_single_click,button_2_double_click,button_2_long_pressbutton_3_single_click,button_3_double_click,button_3_long_pressbutton_4_single_click,button_4_double_click,button_4_long_pressbutton_lower_single_click,button_lower_double_click,button_lower_long_pressbutton_raise_single_click,button_raise_double_click,button_raise_long_press
Example:
button_1_single_click,button_2_single_click,button_1_double_click,button_3_long_press
Passcode Matched Action
Define what happens when the passcode sequence is successfully entered. This can be any Home Assistant action (lights, scripts, scenes, notifications, etc.).
Helper Entities (required)
These are used to store the passcode state as it is being entered.
- Passcode In-Progress: Select the
input_texthelper to store the current sequence - Last Press Time: Select the
input_datetimehelper to track timing between presses
Advanced Settings
- Long Press Timeout (default: 500ms) - How long to hold before triggering a long press
- Double Click Timeout (default: 250ms) - Maximum time between clicks for double-click detection
- Next-In-Sequence Timeout (default: 3s) - Time allowed between sequence steps before the passcode resets. If the user does not press the next keypress in time, they will need to start the code again. The default will need to be raised if the passocde requires very long button presses.
- Debug Mode (default: off) - Enable Home Assistant notifications showing detailed passcode progress and timeouts.
Example Use Cases
Example 1: Simple 4-Button Code to Unlock Door
Passcode Sequence:
button_1_single_click,button_2_single_click,button_3_single_click,button_4_single_click
Passcode Matched Action:
- action: lock.unlock target: entity_id: lock.front_door - action: notify.mobile_app data: message: “Front door unlocked via keypad”
Example 2: Complex Pattern with Mixed Actions
Passcode Sequence:
button_1_double_click,button_2_long_press,button_1_single_click,button_raise_single_click
- action: scene.turn_on target: entity_id: scene.guest_mode - action: persistent_notification.create data: title: “Guest Mode Activated” message: “Guest mode activated via keypad combination”
Example 3: Panic Button Sequence
Passcode Sequence:
button_lower_long_press,button_raise_long_press,button_lower_long_press
- action: script.turn_on target: entity_id: script.emergency_lights_and_siren - action: notify.family data: message: “EMERGENCY: Panic button activated at home” data: priority: high
Example 4: Hidden Admin Menu
Passcode Sequence:
button_1_single_click,button_1_single_click,button_2_single_click,button_2_single_click
- action: input_boolean.turn_on target: entity_id: input_boolean.admin_mode - action: light.turn_on target: entity_id: light.status_indicator data: color_name: purple brightness_pct: 100
Example 5: Multi-Stage Lighting Control
Passcode Sequence:
- action: script.turn_on target: entity_id: script.party_mode_lighting_sequence
How It Works
- Each button press is detected and classified (single click, double click, or long press)
- The action is appended to the passcode progress (
input_texthelper) - If the progress doesn’t match the start of your configured sequence, it resets
- If no button is pressed within the timeout period, the progress resets
- When the progress exactly matches the configured sequence, your action triggers and the progress resets
Troubleshooting
Passcode Not Triggering
- Enable Debug Mode in Advanced Settings to see progress notifications
- Verify your helper entities are configured correctly
- Check that button behaviors are set to Single Action in Lutron Designer
- Ensure your passcode sequence uses valid action names (check spelling and underscores)
Sequence Keeps Resetting
- Check the Next-In-Sequence Timeout - you may need to increase it if you’re pressing buttons slowly
- Enable Debug Mode to see when and why timeouts occur
- Verify the sequence you’re entering matches the configured sequence exactly
Wrong Action Triggering
Double-check your passcode sequence configuration for typos or incorrect action names. The blueprint validates action names and will show a persistent notification if invalid tokens are detected.
Related Blueprints
For general button event handling and LED sync behavior, see the main Lutron Sunnata Keypad Blueprints.
Contributing
Found a bug or have a feature request? Please open an issue on GitHub!
License
This blueprint is released under the Apache License 2.0.
