So I’ve been using a combination of scripts and automations to turn on and off switches that control heaters, and climate devices that heat, (a go control thermostat for a oil heater), and some z wave switches that control relays that control air conditioners that are set to a ridiculously low temperature as to keep cooling until turned off by the relay, that is turned off by aforementioned z wave switch. Is there a good blueprint that could encompass this sort of task or one close enough? Never used blueprints and just realized how they work, and kinda just realized they exist
