Hydro-Québec 3-Stage Dynamic Peak Manager (Preheat, Shed, Recovery)
Automate Hydro-Québec winter dynamic pricing events (Tarif Flex D, Crédit hivernal, or Hilo) across the entire home in three distinct, automated stages:
- Preheat Phase ($T-2\text{h}$): Temporarily boosts heating setpoints, charges the domestic water heater tank to 100% capacity, and pre-ventilates indoor air.
- Peak Event (Load Shedding): Lowers thermostats to setback, turns off high-draw 240V water heaters (Sinopé RM3500WF / Calypso), pauses HRV/air exchangers, engages optional hardware button lockouts to prevent accidental cold-air boost triggers, and sheds non-essential lights.
- Recovery Phase: Restores comfort setpoints, reactivates the water heater, releases hardware lockouts, resumes ventilation, and conditionally restores evening lights if the sun is below the horizon.
Features
- Negative Calendar Trigger Offset: Uses native
calendartriggers with configurable offset (default:-02:00:00) to fire preheating ahead of peak events automatically. - Dual Triggering: Operates reliably via calendar events (
calendar.hydro_quebec_peak_calendarorics_calendar) AND binary sensors (binary_sensor.hydro_quebec_*_critical_peak_active). - Thermal Battery Management: Takes advantage of the 40–60 gallon water heater tank and thermal mass of walls/floors to eliminate electricity draw during 53¢/kWh peaks without comfort sacrifice.
- Ventilation / HRV Hardware Lockout: Automatically stops sub-zero outdoor air infiltration and physically disables manual wall/bathroom buttons during the peak window.
- Solar Recovery: Checks
sun.sunpost-peak so evening outdoor/ambient lighting only resumes if it is actually dark outside.
