Blueprint input_boolean entity_id
I’m making a blueprint script where I want to allow the user to select an input boolean, which will be used as a condition later on.
This is my script:
blueprint:
  name: AL ES Adaptive Lights
  description: Change lights based on time of day
  domain: script
  input:
    target_light:
      description: The light(s) with kelvin
      selector:
        entity:
          filter:
            - domain: light
          multiple: true
    start_time:
      description: Time to start the automation
      selector:
        time: {}
      default: null
    end_time:
      description: Time the script should end
      selector:
        time: {}
    start_template:
      description: Start based on a template
      selector:
        template:
      default: false
    steps_per_minute:
      name: Steps per minute for all runs
      description: Used for configuring percentage of each step for brightness and color temperature
      default: 5
      selector:
        number:
          min: 1
          max: 12
    start_kelvin:
      description: Start Kelvin value
      selector:
        color_temp:
          unit: kelvin
      default: ""
    end_kelvin:
      description: >-
        Target Kelvin value
      selector:
        color_temp:
          unit: kelvin
    start_bright:
      name: Start brightness
      description: Start brightess percent
      selector:
        number:
          min: 1
          max: 100
      default: ""
    end_bright:
      name: Maximum Brightness
      description: End brightness percent
      selector:
        number:
          min: 1
          max: 100
      default: ""
    manual_override:
      name: Input boolean for manual changes
      description: Stop change of lights when manual change is made
      selector:
        entity:
          filter:
            - domain:
                - input_boolean
    reminder_continue_change:
      name: Reminder to continue light change
      description: >-
        Send an actionable notification after time has passed to continue the light change
      selector:
        time: {}
      default: "00:30:00"
mode: single
variables:
  start_time: !input start_time
  end_time: !input end_time
  target_light: !input target_light
  steps_per_minute: !input steps_per_minute
  start_kelvin: !input start_kelvin
  end_kelvin: !input end_kelvin
  start_bright_pct: !input start_bright
  end_bright_pct: !input end_bright
  manual_override: !input manual_override
  duration: >
    {% set start = strptime(start_time, '%H:%M:%S') %}
    {% set end = strptime(end_time, '%H:%M:%S') %}
    {% set duration = (end_time - start_time).total_seconds() / 60 %}
  intervals: "{{ duration * steps_per_minute | int }}"
  step_kelvin: "{{ ((end_kelvin - start_kelvin) / intervals) | round}}"
  step_bright: "{{ ((end_bright - start_bright) / intervals) | round }}"
sequence:
  - variables:
      current_bright: "{{ state_attr(target_light, 'brightness') | default(min_bright) }}"
      current_kelvin: "{{ state_attr(target_light, 'color_temp_kelvin') | default(min_kelvin) }}"
      start_bright: "{{ (start_bright_pct * 255 / 100) | round }}"
      end_bright: "{{ (end_bright_pct * 255 / 100) | round }}"
      step_kelvin: "{% if (start_kelvin > end_kelvin) %} {{ step_kelvin * (-1) }} {% else %} {{ step_kelvin }} {% endif %}"
      step_bright: "{% if (start_bright > end_bright) %} {{ step_bright * (-1) }} {% else %} {{ step_bright }} {% endif %}"
  - service: light.turn_on
      entity_id: "{{ target_light }}"
      brightness: "{{ start_bright }}"
      color_temp_kelvin: "{{ start_kelvin }}"
  - delay:
      seconds: 2
  - repeat:
      until:
        - condition: or
          conditions:
            - condition: state
              entity_id: "{{ manual_override }}"
              state: "on"
            - condition: template
              value_template: "{{ repeat.index == intervals | int }}"
      sequence:
          target: "{{ target_light }}"
            brightness: "{{ (start_bright + (step_bright * repeat.index)) | int }}"
            color_temp_kelvin: "{{ (start_kelvin + (step_kelvin * repeat.index)) | int }}"
        - delay:
            seconds: 2
It gives the following error:
Error:Entity {{ manual_override }} is neither a valid entity ID nor a valid UUID for dictionary value @ data['sequence'][3]['repeat']['until'][0]['conditions'][0]['entity_id']. Got '{{ manual_override }}' .
Why is that?
Considering the blueprint posted never does anything with the manual_override variable after settings its value, nor does any of the conditions within the loops until even have an entity_id, I’d say you have either posted the wrong blueprint code or the wrong error message…?
Dang… thanks, I edited with the correct blueprint
Well that makes it obvious. Templates are not supported for any of the properties on neither state triggers nor state conditions. Either insert the entity id directly from the blueprint with !input or rewrite the state condition as a template condition.
Thanks. I honestly don’t know what I’m doing at this point.
I changed both the entity_ids, the templated entity_ids and whatnot.
But now it’s working, thanks a lot for your help!
