esphome:
friendly_name: xx_789a6b
esp8266:
board: d1_mini
# Enable logging
logger:
level: info
# Enable Home Assistant API
api:
encryption:
key: "hash"
reboot_timeout: 0s
services:
- service: beep_code
variables:
repeat_count: int
delay_ms: int
then:
- script.execute:
repeat_count: !lambda return repeat_count;
delay_ms: !lambda return delay_ms;
on_client_disconnected:
then:
- script.execute: failsafe_mode
ota:
password: "hash"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "xx-789A6B Fallback Hotspot"
password: "hash"
reboot_timeout: 0s
use_address: static
captive_portal:
- platform: uptime
output:
- platform: gpio
pin: D7
switch:
- platform: restart
- platform: gpio
pin: D5
icon: mdi:engine
binary_sensor:
- platform: gpio
pin:
number: D1
inverted: true
mode:
input: true
pullup: true
filters:
- delayed_on_off: 1s
on_press:
then:
- switch.turn_on: relay1
on_release:
then:
- switch.turn_off: relay1
on_state:
then:
- script.execute:
repeat_count: 1
delay_ms: 150
script:
- id: beep_code
parameters:
repeat_count: int
delay_ms: int
then:
- repeat:
then:
- output.turn_on: buzzer
- delay: !lambda return delay_ms;
- output.turn_off: buzzer
- id: failsafe_mode
then:
- if:
condition:
and:
- switch.is_on: relay1
- binary_sensor.is_off: switch1
then:
- script.execute:
repeat_count: 3
delay_ms: 150
commit
critical heavy appliance (ex. motor pump, submersible) need to control with safety measure.
feature
1.manual control (work without any connectivity)
2.failsafe mode (device turn off in case of connection lost)
schematic
- binary gpio connected to standard ac switch (switch_pin0 ~ gnd, switch_pin1 ~ binary gpio)
- relay gpio connected to ssr or mechanical relay (preffer ssr for stability)
- buzzer gpio connected to 5v buzzer (active buzzer)
