Blueprint MQTT Triggers Not Firing Using Variables - core-2025.3.4
Hi everyone,
I’m hoping someone can shed some light on a baffling issue I’m having with MQTT triggers defined within a blueprint. I’m running Home Assistant Core 2025.3.4 but my challenge to get this working existed before that version as well. Below, my apologies as I’ve replaced some of my topics, etc. for generic purposes here.
The Goal: I’m trying to create a blueprint that listens to MQTT messages from a Tasmota device (specifically the stat/.../RESULT topic containing button press actions like {"Button1":{"Action":"SINGLE"}}) to basically select which light (recording this to a helper), then use buttons 3/2 to dim up/down respectively. The device I am working on is a MJ SD01 with Tasmota 14.4.1. Everything is fine when I manually specify the mqtt trigger, but the failure point, through dozens of trials to refine this, is the use of variables to define the mqtt trigger.
  1. MQTT Messages Received: Using the Home Assistant Developer Tools MQTT listener, I can clearly see the correct JSON payloads arriving on the correct stat/YOUR_TASMOTA_BASE_TOPIC/RESULT topic when I press the buttons.
  2. Standalone Automation Works: If I create a simple, standalone automation (not using a blueprint) with the platform: mqtt, topic:, and payload: hardcoded to match the exact message seen in the listener, it triggers perfectly every time.
This strongly suggests the issue lies specifically with how MQTT triggers are processed when defined within a blueprint, potentially related to how variables/inputs are templated in the 'topic or payload fields.
Troubleshooting Steps Taken:
  • Confirmed MQTT messages are correct via Tasmota console and HA MQTT listener.
  • Verified the automation created from the blueprint is enabled.
  • Verified blueprint inputs (mqtt_device_topic, button_number, helpers) are correct in the automation’s configuration.
  • Corrected an initial template syntax error (using !input inside {{}}).
  • Tried using direct templating in the trigger (e.g., topic: "stat/{{ mqtt_device_topic }}/RESULT"). → Failed
  • Tried pre-computing the full trigger topic/payload strings in a variables: block and referencing those variables in the trigger (e.g., topic: "{{ trigger_topic_str }}"). → Failed
  • Created a drastically simplified blueprint focusing only on a single button press trigger/action. → Failed
  • Reloaded blueprints and restarted Home Assistant Core multiple times.
  • Checked HA Core logs - no errors appear related to the automation or triggers when buttons are pressed.
Code Examples:
1. Non-Working Simplified Blueprint (your_simple_blueprint_filename.yaml): (This version tries pre-computing variables)
blueprint:
  name: Tasmota Simple Test - Button 1 Single Press
  description: |-
    Further simplified blueprint for testing Button 1 single press MQTT trigger.
    Uses intermediate variables for trigger construction.
  domain: automation
  input:
    mqtt_device_topic:
      name: Tasmota Device Base Topic
      description: The base topic of your Tasmota device (e.g., tasmota_XXXXXX).
      default: ""
    button_number:
      name: Button Number for Single Press
      description: The button number on your Tasmota device (usually 1).
      default: 1
      selector:
        number:
          min: 1
          max: 8
          mode: box
    single_press_device:
      name: Device for Single Press
      description: The light entity to be toggled on single press.
      selector:
        entity:
          domain: light
    selected_light_helper:
      name: Selected Light Helper (Input Text)
      description: An input_text helper to store the entity_id of the toggled light.
      selector:
        entity:
          domain: input_text
variables:
  # Assign inputs to intermediate variables
  var_topic_base: !input mqtt_device_topic
  var_button_num: !input button_number
  # Construct full trigger strings using intermediate variables
  trigger_topic_str: "stat/{{ var_topic_base }}/RESULT"
  trigger_payload_str: '{"Button{{ var_button_num }}":{"Action":"SINGLE"}}'
  # Reference the fully constructed variables
  - platform: mqtt
    payload: "{{ trigger_payload_str }}"
condition: [] # No conditions
  # Action remains the same
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - service: light.toggle
              entity_id: !input single_press_device
          - service: input_text.set_value
              entity_id: !input selected_light_helper
              value: !input single_press_device
    default: []
mode: restart
2. Working Standalone Automation (YAML):
alias: MQTT Trigger Test - Button 1 Single
description: "Temporary test for MQTT trigger"
  - platform: mqtt
    topic: stat/YOUR_TASMOTA_BASE_TOPIC/RESULT # Hardcoded topic
    payload: '{"Button1":{"Action":"SINGLE"}}'      # Hardcoded payload
condition: []
  - service: persistent_notification.create # Simple action
      message: "MQTT Test Trigger Fired Successfully!"
      notification_id: "{{ trigger.id }}"
mode: single
3. Example MQTT Message (from HA Listener): Topic: stat/YOUR_TASMOTA_BASE_TOPIC/RESULT Payload: {"Button1":{"Action":"SINGLE"}}
4. Example Automation Config from Blueprint (Non-working):
alias: (Your Automation Name) # Example name
description: ""
use_blueprint:
  path: your_simple_blueprint_filename.yaml # Or whatever the filename is
  input:
    mqtt_device_topic: YOUR_TASMOTA_BASE_TOPIC
    button_number: 1
    single_press_device: light.your_single_press_light # Example light
    selected_light_helper: input_text.your_selection_helper # Example helper
Question: Has anyone else encountered issues with platform: mqtt triggers defined inside blueprints failing like this? I searched for a while, so my apologies if I am duplicating another thread. Is there a known bug, a different required syntax for templating MQTT topics/payloads in blueprints, or any other debugging step I might be missing?
Thanks so much for any helpful insights you can offer!
Variables that need to be available for the trigger need to be in a trigger_variables block.
Thanks for the quick response! I tried altering accordingly and repeating the troubleshooting, but unfortunately still can’t seem to get the trigger to work when using variables. Looking at the actual blueprint, any other ideas? All are welcome!
I’m having a similar issue as I’ve documented in Trigger Variables are Giving Me a Headache - #10 by Didgeridrew
Were you able to figure out how to use variables in mqtt triggers?
