This blueprint keeps Philips Hue scenes persistent in Home Assistant—even when individual lights are toggled, added, or restored within an already active room or zone.
Whenever a Hue room or zone returns to a fully ON state, the blueprint automatically re-applies the last active Hue scene, ensuring visual consistency across all lights.
Features
- Automatic Persistence: Re-applies the last active Hue scene once a room or zone becomes fully ON.
- Smart Detection: Supports Hue Rooms and Hue Zones (automatically detected via the
is_hue_groupattribute). - Brightness Integrity: Restores per-light brightness for rooms and group brightness for zones to maintain your manual adjustments after the scene refresh.
- Dynamic Support: Optional dynamic scene support with configurable playback speed.
- Flicker Prevention: Uses
mode: restartto collapse rapid state changes (like a group of lights turning on) into a single final refresh. - Granular Exclusions: Exclude specific lights from the “Fully ON” check or from brightness restoration.
Requirements
- Home Assistant 2025.12.4 or newer (due to advanced template features).
- Home Assistant Labs (Purpose-specific triggers and conditions)
- Philips Hue Integration (Official).
- Hue-Native Scenes: Scenes must be created in the Hue App and synced to Home Assistant. This blueprint targets the
group_nameattribute provided by the Hue integration.
Important: Scene Naming & Logic
This blueprint relies on a matching link between your Hue Scenes and their corresponding Hue Group.
The Requirement
The blueprint determines the last active scene by selecting scenes where the group_name attribute matches the room or zone’s Friendly Name.
Note: As long as your scene belongs to the correct Room/Zone in the Hue App, this will work automatically. If you have renamed entities manually in Home Assistant and broken this link, the blueprint cannot reliably determine which scene to restore.
Configuration
Triggers
- Target Light(s): The lights, rooms, or zones you want to monitor. Any state change here will trigger the evaluation.
- Trigger Delay: A small buffer (default 1s) to allow the Hue Bridge to synchronize its state before the automation takes action.
- Alternative Triggers: Alternative triggers must provide a
light.*entity_id from the Philips Hue integration.
Scene Options
- Transition Time: The smoothness of the scene refresh.
- Dynamic Scene Speed: Sets the playback speed for animated scenes.
- Targets with Dynamic Scenes: Define which rooms/zones should always use the “dynamic” mode when refreshed.
Advanced Options
- Ignore Active Effects: If set to
false, the automation will stop if it detects a light running an effect (to avoid interrupting your party mode!). - Exclusions: You can exclude specific lights from being checked for the “Room ON” state or from having their brightness restored.
Blueprint
Click the badge to import this Blueprint:
Or copy the code directly:
Click to see the code
blueprint:
name: Hue Scene Refresher
domain: automation
author: Electro_Attacks
description: >
Refreshes the last active Philips Hue scene for a room or zone when lights
change state. Supports dynamic scenes, brightness restoration, effect safety
checks, and alternative trigger sources.
homeassistant:
min_version: 2025.12.4
input:
triggers:
icon: mdi:flash
description: Configure which events should cause the scene refresh.
input:
targets:
description: >
Hue lights, rooms, or zones that should be observed for state changes.
Any ON/OFF transition within this target will trigger the automation.
selector:
device:
integration: hue
entity:
domain: light
state_trigger_delay:
description: >
Delay (in seconds) before evaluating the scene state after a light
changes. Useful to allow Hue to fully settle its internal state.
default: 1
selector:
number:
min: 1
max: 100
step: 1
unit_of_measurement: sec
mode: slider
alternative_triggers:
description: >
Optional additional triggers (e.g. attribute changes).
These triggers must resolve to a Hue light entity to be considered valid.
default: []
selector:
scene_options:
icon: mdi:palette
description: Scene behavior and animation configuration.
input:
transition_time:
description: >
Transition duration (in seconds) used when activating scenes or restoring brightness.
default: 3
selector:
number:
min: 1
max: 100
step: 1
mode: slider
dynamic_scene_speed:
name: Dynamic Scene Speed
description: >
Playback speed for dynamic Hue scenes. Lower values are slower.
default: 60
selector:
number:
min: 1
max: 100
step: 1
mode: slider
targets_with_dynamic_scenes:
name: Targets with Dynamic Scenes
description: >
Rooms or zones that should activate scenes in dynamic mode.
default: []
selector:
device:
integration: hue
entity:
domain: light
advanced_options:
icon: mdi:cog
description: Optional safety and exclusion rules.
collapsed: true
input:
ignore_active_effects:
name: Ignore Active Effects
description: >
If enabled, scenes may be refreshed even when lights currently have
active effects (e.g. color loop).
default: false
selector:
boolean:
targets_excluded_from_state_check:
name: Targets Excluded from State Check
description: >
Lights that should be ignored when determining whether a room or zone
is considered fully ON.
default: []
selector:
device:
integration: hue
entity:
domain: light
targets_excluded_from_brightness_restore:
name: Targets Excluded from Brightness Restore
description: >
Lights that should not have their brightness restored after a scene refresh.
default: []
selector:
device:
integration: hue
entity:
domain: light
mode: restart
max_exceeded: info
triggers:
- alias: Detect any light in target group turning ON
trigger: light.turned_on
target: !input targets
options:
behavior: any
- alias: Detect any light in target group turning OFF
trigger: light.turned_off
options:
behavior: any
- triggers: !input alternative_triggers
conditions:
- alias: Pass if triggered by state change or valid Hue light
condition: or
conditions:
- alias: Triggered by Hue state change
condition: trigger
- alias: Triggered externally but resolved to Hue light
condition: and
conditions:
- alias: Not triggered by primary state_change
condition: not
conditions:
- condition: trigger
- alias: Trigger entity_id is valid
condition: template
value_template: "{{ trigger.entity_id is string }}"
- alias: Entity belongs to light domain
condition: template
value_template: "{{ trigger.entity_id.split('.')[0] == 'light' }}"
- alias: Entity belongs to Philips Hue integration
condition: template
value_template: >
{% set ids = device_attr(trigger.entity_id, 'identifiers') or [] %}
{{ ids | selectattr(0, 'eq', 'hue') | list | count > 0 }}
variables:
dynamic_scene_targets: !input targets_with_dynamic_scenes
state_check_exclusions: !input targets_excluded_from_state_check
brightness_restore_exclusions: !input targets_excluded_from_brightness_restore
allow_active_effects: !input ignore_active_effects
dynamic_scene_speed: !input dynamic_scene_speed
scene_transition_time: !input transition_time
actions:
- delay: !input state_trigger_delay
- alias: Resolve target selectors into concrete light entities
variables:
resolved_targets: >
Converts Home Assistant target selectors (entity / device / area / label)
into flat, unique lists of light entities.
{%- macro resolve_targets(source, returns) -%}
{# Direct entity targets #}
{%- set entities =
source.entity_id if source.entity_id is list
else ([source.entity_id] if source.entity_id is defined else [])
{# Hierarchical targets #}
{%- set floors =
(source.floor_id | map('floor_entities') | list | sum(start=[]))
if source.floor_id is list else
(floor_entities(source.floor_id) if source.floor_id is defined else [])
{%- set areas =
(source.area_id | map('area_entities') | list | sum(start=[]))
if source.area_id is list else
(area_entities(source.area_id) if source.area_id is defined else [])
{%- set devices =
(source.device_id | map('device_entities') | list | sum(start=[]))
if source.device_id is list else
(device_entities(source.device_id) if source.device_id is defined else [])
{%- set labels =
(source.label_id | map('label_entities') | list | sum(start=[]))
if source.label_id is list else
(label_entities(source.label_id) if source.label_id is defined else [])
{# Merge, filter and de-duplicate light entities #}
{%- do returns(
(entities + floors + areas + devices + labels)
| select('match', '^light\.')
| unique
| list
{%- endmacro -%}
{% set fn = resolve_targets | as_function %}
'dynamic': fn(dynamic_scene_targets),
'state_excluded': fn(state_check_exclusions),
'brightness_excluded': fn(brightness_restore_exclusions)
- alias: Determine Hue room and related zones for trigger entity
variables:
area_context: >
Determines the Hue room affected by the trigger and
all zones that overlap with that room.
{% set hue_groups =
states.light
| selectattr('attributes.is_hue_group','eq',true)
| list
{% set room_entity = none %}
{# Trigger is already a Hue group #}
{% if is_state_attr(trigger.entity_id, 'is_hue_group', true) %}
{% if is_state_attr(trigger.entity_id, 'hue_type', 'room') %}
{% set room_entity = trigger.entity_id %}
{% else %}
{% set first_light = state_attr(trigger.entity_id,'entity_id') | first %}
hue_groups
| selectattr('attributes.hue_type','eq','room')
| selectattr('attributes.entity_id','contains', first_light)
| map(attribute='entity_id')
| first
{% endif %}
{% else %}
{# Trigger is a single light #}
hue_groups
| selectattr('attributes.entity_id','contains', trigger.entity_id)
| first
{% endif %}
{# Collect overlapping zones #}
{% set ns = namespace(zones=[]) %}
{% if room_entity %}
{% set room_lights = state_attr(room_entity,'entity_id') %}
{% for zone in hue_groups | selectattr('attributes.hue_type','eq','zone') %}
{% if state_attr(zone.entity_id,'entity_id') | select('in', room_lights) | list %}
{% set ns.zones = ns.zones + [zone.entity_id] %}
{% endif %}
{% endfor %}
{% endif %}
{{ { 'room': room_entity, 'zones': ns.zones | unique | list } }}
- alias: Snapshot current scene, brightness and state for affected areas
variables:
area_snapshot: >
Captures:
- Whether room/zones are fully ON
- Last active Hue scene per group
- Brightness levels for restoration
{% set snapshot = namespace(room = none, zones = []) %}
{% set groups =
area_context.zones +
([area_context.room] if area_context.room else [])
{% for group in groups %}
{% set members = state_attr(group,'entity_id') or [] %}
{% set lights =
expand(members)
| rejectattr('entity_id','in', resolved_targets.state_excluded)
| selectattr('state','ne','unknown')
| list
{% set active = lights | selectattr('state','eq','on') | list %}
{% set effect_capable =
active | selectattr('attributes.effect','ne', undefined) | list
{% set effects_clear =
allow_active_effects or
(effect_capable
| selectattr('attributes.effect','in',[none,'off','none','None'])
| list | count == effect_capable | count)
{% set is_area_on =
lights | count > 0 and
active | count == lights | count and
effects_clear
{% set scenes =
states.scene
| selectattr('attributes.group_name', 'eq', state_attr(group, 'friendly_name'))
| sort(attribute='state', reverse=true)
| list
{% set group_data = {
'entity_id': group,
'brightness': state_attr(group,'brightness'),
'is_area_on': is_area_on,
'last_scene': scenes | first
{% if group == area_context.room %}
{# Capture per-light brightness for room restoration #}
{% set light_snapshot = namespace(items=[]) %}
{% for light in active %}
{% set light_snapshot.items = light_snapshot.items + [{
'entity_id': light.entity_id,
'brightness': light.attributes.brightness
{% endfor %}
{% set group_data = group_data | combine({
'active_lights': light_snapshot.items
{% set snapshot.room = group_data %}
{% elif is_area_on %}
{% set snapshot.zones = snapshot.zones + [group_data] %}
{% endif %}
{% endfor %}
{{ { 'room': snapshot.room, 'zones': snapshot.zones } }}
- alias: Decide whether full room scene refresh is allowed
if:
- alias: Room is fully ON and valid for scene refresh
condition: template
value_template: "{{ area_snapshot.room.is_area_on }}"
then:
- alias: Build scene activation data for room
variables:
scene_data: >
Scene payload for Hue room activation.
Dynamic mode and brightness restoration are applied conditionally.
{% set data = {
'dynamic': area_snapshot.room.entity_id in resolved_targets.dynamic,
'speed': dynamic_scene_speed,
'transition': scene_transition_time
{% if area_snapshot.room.entity_id not in resolved_targets.brightness_excluded %}
{% set data = data | combine({
'brightness': area_snapshot.room.brightness
{% endif %}
{{ data }}
- alias: Activate last known scene for room
action: hue.activate_scene
entity_id: "{{ area_snapshot.room.last_scene }}"
data: "{{ scene_data }}"
- alias: Wait for scene transition to complete
delay: "{{ scene_transition_time }}"
- alias: Restore brightness for active zones in room
repeat:
for_each: "{{ area_snapshot.zones }}"
sequence:
- alias: Zone is allowed for brightness restoration
condition: template
value_template: >
{{ repeat.item.entity_id not in resolved_targets.brightness_excluded }}
- alias: Zone brightness differs from snapshot
condition: template
value_template: >
{{ state_attr(repeat.item.entity_id,'brightness') != repeat.item.brightness }}
- alias: Restore zone brightness
action: light.turn_on
entity_id: "{{ repeat.item.entity_id }}"
brightness: "{{ repeat.item.brightness }}"
transition: "{{ scene_transition_time }}"
else:
- alias: Refresh scenes for zones only (room not fully ON)
repeat:
sequence:
- alias: Build scene activation data for zone
variables:
scene_data: >
Scene payload for Hue zone activation.
Brightness restoration is optional.
{% set data = {
'dynamic': repeat.item.entity_id in resolved_targets.dynamic,
{% if repeat.item.entity_id not in resolved_targets.brightness_excluded %}
'brightness': repeat.item.brightness
{% endif %}
{{ data }}
- alias: Activate last known scene for zone
entity_id: "{{ repeat.item.last_scene }}"
- alias: Restore brightness for individual lights in room
repeat:
for_each: "{{ area_snapshot.room.active_lights | default([]) }}"
sequence:
- alias: Light is allowed for brightness restoration
condition: template
value_template: >
- alias: Light brightness differs from snapshot
condition: template
value_template: >
- alias: Restore individual light brightness
How It Works
- Context Resolution: When a light changes state, the blueprint identifies which Hue Room it belongs to and checks for overlapping Zones.
- Snapshotting: It captures the current brightness and state of every light in that room before applying the refresh.
- Validation: It confirms that the room is “Fully ON” (all lights active and no forbidden effects like Color Loop running).
- Refresh & Restore: It calls
hue.activate_scene. Because scenes can sometimes override manual brightness, it then performs a precision restore of the brightness levels captured in step 2.
Technical Notes
- Mode: Restart: This is intentional. It ensures that if five lights turn on at once, the automation restarts five times and only executes the refresh once for the final state.
- Target Selectors: Fully compatible with the 2025.12 target selection (Areas, Floors, Labels, etc.)
Change Log
v1.0
- Initial release.
- Support for Hue Rooms/Zones persistence.
- Dynamic scene and brightness restoration.
