This project allows you to update an input_text
field with the last real update of an entity, excluding Home Assistant restarts.
Description:
It uses an automation in Home Assistant that records the last update of a specified entity into an input_text
field. This allows you to track the last update of a device, while excluding Home Assistant restarts that would reset the values.
Result
