Hi, I’m trying to make a sunrise automation and the problem (I think) is the error in the log:
homeassistant.components.blueprint.errors.MissingInput: Missing input device_input
This is shown only when the alarm sensor is set.
The whole automation work if triggered manually, but automatically not (even with the manual time).
I hope that someone could help me, Thanks in advance!
blueprint:
description: Wake up with a lovely sunrise
domain: automation
input:
target_device:
selector:
entity:
domain: light
device_input:
selector:
entity:
device_class: timestamp
default: none
datetime:
selector:
time:
default: 00:00:00
duration:
name: Sunrise duration (s)
selector:
number:
min: 60
max: 900
default: 60
brightness:
selector:
number:
min: 0
max: 254
default: 150
write_red:
selector:
number:
min: 0
max: 255
default: 255
write_green:
selector:
number:
min: 0
max: 255
default: 130
write_blue:
selector:
number:
min: 0
max: 255
default: 20
variables:
brightnessact: 0
durationvar: !input duration
step: '{{ float(durationvar)*5/255 }}'
target_light: !input target_device
brg: !input brightness
trigger_variables:
sensor: !input device_input
manual_time: !input datetime
seconds: !input duration
platform: template
value_template: >-
{{0 < as_timestamp(states(sensor) if sensor != 'none' else states('sensor.date')
~ ' ' ~ manual_time) | float - as_timestamp(states('sensor.date_time_iso')) <= float(seconds)}}'
- repeat:
while:
- condition: template
value_template: '{{ state_attr(target_light, "brightness") | int < brg }}'
sequence:
- delay:
seconds: '{{ float(step) }}'
- service: light.turn_on
entity_id: !input target_device
brightness: '{{ state_attr(target_light, "brightness") | int + 5 }}'
rgb_color:
- !input write_red
- !input write_green
- !input write_blue
- delay:
minutes: 10
- service: light.turn_off
