Using the HA UI, I have added a trigger to an existing, working automation. That new trigger incorporates my Bluesound Node N130 (media streamer) as a trigger to turn on other devices.
Those triggers are ‘State Change’ triggers as follows:
- When the Node either ‘Changes from’ ‘Off’ to ‘On’ or;
- When the player changes from ‘Paused’ to ‘Playing’.
My Problem: these triggers only work some of the time.
For details see parameters selected in the attached screenshot.
Note: the trigger that has been working successfully for this automation uses a ‘Manual Event’ trigger (that is unrelated to the Bluesound). Therefore, I would like to create a manual event trigger using an event from the Bluesound Node in the hope that this fixes my problem.
However, I have been unable to do that because I can’t determine the ‘event type’ because I have not been able to listen to the Bluesound events using the Developer Tools, Event Listener.
My question/s:
- Can anyone help by explaining how I might listen to events relating to the Bluesound integration? HA sees the device as a ‘media_player’ - so is there a media player listener I can use?
- If I can’t use an ‘Event’ based trigger should the ‘State Change’ triggers that I have configured be working (i.e. have I configured them incorrectly)?
Background
- The automation in question works beautifully with another trigger that I set up - the devices that I want to switch on and off, toggle correctly.
- I have been able to successfully integrate my Bluesound Node by updating the YAML Configuration file.
- I have been partially successful with the state change automation that incorporates the Bluesound Node into this automation. I say partially because it only works some of the time.
- I have read the documentation for the Bluesound integration here: Bluesound - Home Assistant
- I have also read the Event Listener documentation trying names like Bluesound, BluOS, bluesound_event as event types to listen to - these event types are not correct.
- I have searched the Logs for any Bluesound events - cannot find any.
