Bluethooth not being seen in HASS OS after upgrade
HASS OS on promox
Bluetooth startec USBBT1EDR4 (CSR8510 A10)
  • Core 2025.1.4
  • Supervisor 2024.12.3
  • Operating System 14.2
  • Frontend 20250109.2
everything was working
did the latest updates and restarted this morning and I’m no longer seeing my bluetooth adapter
➜ ~ lsusb
Bus 001 Device 001: ID 1d6b:0001 Linux 6.6.73-haos uhci_hcd UHCI Host Controller
➜ ~ dmesg| grep hci
[ 0.507774] uhci_hcd 0000:00:01.2: UHCI Host Controller
[ 0.508252] uhci_hcd 0000:00:01.2: new USB bus registered, assigned bus number 1
[ 0.508878] uhci_hcd 0000:00:01.2: irq 11, io port 0x0000c0e0
[ 0.510828] usb usb1: Manufacturer: Linux 6.6.73-haos uhci_hcd
[ 0.521330] sdhci: Secure Digital Host Controller Interface driver
[ 0.521757] sdhci: Copyright(c) Pierre Ossman
➜ ~ dmesg| grep Blue
[ 42.130050] Bluetooth: Core ver 2.22
[ 42.130090] Bluetooth: HCI device and connection manager initialized
[ 42.130093] Bluetooth: HCI socket layer initialized
[ 42.130095] Bluetooth: L2CAP socket layer initialized
[ 42.130098] Bluetooth: SCO socket layer initialized
[ 42.228880] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 42.228884] Bluetooth: BNEP filters: protocol multicast
[ 42.228887] Bluetooth: BNEP socket layer initialized
not sure what to look for; heeeelp plz
i enabled Bluetooth debug logs and restarted HA
2025-01-29 07:40:44.719 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration pyscript which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-29 07:40:44.719 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-29 07:40:44.720 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration vesync which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-29 07:40:44.720 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration elkbledom which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-29 07:40:44.720 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration frigate which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-29 07:44:26.983 DEBUG (MainThread) [homeassistant.components.bluetooth] Triggering bluetooth usb discovery
2025-01-29 07:44:31.985 DEBUG (MainThread) [homeassistant.components.bluetooth] Rediscovered adapters: {}
2025-01-29 07:46:36.986 DEBUG (MainThread) [homeassistant.components.bluetooth] Rediscovered adapters: {}
2025-01-29 07:47:27.794 DEBUG (MainThread) [homeassistant.components.bluetooth] Triggering bluetooth usb discovery
issue was related to proxmox, had to map the USB device
