Bluetooth and raspberry pi
Has anyone had any luck getting a bluetooth speaker to work with the latest raspberry pi 3 build? It finds my speaker, but when I try to change to that speaker under audio control, it gives me a cryptic file not found error. I found one other person that had the problem out on the raspberry pi board, but he never got an answer.
Did you ever find a solution to this? I am curious about outputting TTS from an RPi3 via Bluetooth audio (to a Bluetooth lightbulb speaker in the room).
I ended up rebuilding after that and it worked correctly from a new build
Could you help us with a guideline ?
Thanks.
