Bluetooth dongle not being recognized
I’m using Home Assistant OS as VM. I bought the EDUP B3536 bluetooth dongle from Aliexpress (this one).
it’s on the list of supported devices for the Bluetooth integration, at least that’s what I understand.
In the computer running the VM, I see it recognized as “Realtek Bluetooth Radio” with ID: 2550:8761 –
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 003: ID 174c:3074 ASMedia Technology Inc. ASM1074 SuperSpeed hub
Bus 002 Device 002: ID 0781:5583 SanDisk Corp. Ultra Fit
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 007: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T
Bus 001 Device 005: ID 067b:2586 Prolific Technology, Inc. USB 2.0 Hub
Bus 001 Device 003: ID 0b05:19af ASUSTek Computer, Inc. AURA LED Controller
Bus 001 Device 012: ID 2550:8761 Realtek Bluetooth Radio
Bus 001 Device 009: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
Bus 001 Device 006: ID 0463:ffff MGE UPS Systems UPS
Bus 001 Device 004: ID 046d:c534 Logitech, Inc. Unifying Receiver
Bus 001 Device 002: ID 174c:2074 ASMedia Technology Inc. ASM1074 High-Speed hub
Bus 001 Device 008: ID 1044:7a51 Chu Yuen Enterprise Co., Ltd GIGABYTE CPU Cooler
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I passthrough it into the VM, and from the Home Assistant’s Terminal & SSH Addon, I can see that the ID is there when I run “lsusb”.
However the Bluetooth integration can’t find it.
Anything else I can try? (BT Proxy is not an option for me here, I need the BT accessible from inside a different addon in Home Assistant, unless there’s a way to pass BT Proxy to an addon which I’m missing).
instead of lsusb, type dmesg which will output a lot of text. Within all that text you’ll see where the BT Stick was found based on its ID, but look further down to see some stuff like:
Bluetooth: Core ver 2.22
usbcore: registered new interface driver btusb
Bluetooth: hci0: RTL: blah-blah
and see if there are any failures.
