Bluetooth errors on new install
Hi Everyone,
Following completion of my build:
Home Assistant 2022.11.1
Supervisor 2022.10.2
Operating System 9.3
Frontend 20221102.1 - latest
On Intel x86 hardware
I’m getting the following error continuously:
Bluetooth: hci0: unexpected event for opcode 0x2005
I’ve not got any bluetooth devices connect to HA, but do have some nearby.
I can see that there were some major updates done to bluetooth recently that look like they should have fixed this - any ideas?
Thanks.
just loaded the x86 image on x86 box and I am getting the same error.
On the host terminal direct (not via ssh) the terminal is constantly being interrupted by this message to the point that the cli is not really usable.
If I run systemctl stop bluetooth then I can get that error to stop but I can not run systemctl disable bluetooth
# systemctl disable bluetooth
Failed to disable unit: File /etc/systemd/system/bluetooth.target.wants/bluetooth.service: Read-only file system
So either I have to figure out a way to disable the service on startup or I need to resolve the kernel? error. I guess if noone can help here I’ll report a bug to hassos repo.
I don’t need bluetooth (for now) so disabling would be ok
arch: amd64
channel: stable
docker: 24.0.7
features:
- reboot
- shutdown
- services
- network
- hostname
- timedate
- os_agent
- haos
- resolved
- journal
- disk
- mount
hassos: "11.2"
homeassistant: 2023.12.3
hostname: homeassistant-temp
logging: info
machine: generic-x86-64
operating_system: Home Assistant OS 11.2
state: running
supervisor: 2023.12.0
supported: true
supported_arch:
- amd64
- i386
Kernel 6.6 is now LTS. I have lots of hardware bought in the last few months that have issue with various subsystems with anything less that 6.6. Now that 6.6 is LTS hassos should be upgraded (maybe a major upgrade).
# ha host logs -t kernel -n 1000000 -b 0 | grep Bluetooth | head -n 100
Dec 24 01:39:20 homeassistant kernel: Bluetooth: Core ver 2.22
Dec 24 01:39:20 homeassistant kernel: Bluetooth: HCI device and connection manager initialized
Dec 24 01:39:20 homeassistant kernel: Bluetooth: HCI socket layer initialized
Dec 24 01:39:20 homeassistant kernel: Bluetooth: L2CAP socket layer initialized
Dec 24 01:39:20 homeassistant kernel: Bluetooth: SCO socket layer initialized
Dec 24 01:39:35 homeassistant kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Dec 24 01:39:35 homeassistant kernel: Bluetooth: BNEP filters: protocol multicast
Dec 24 01:39:35 homeassistant kernel: Bluetooth: BNEP socket layer initialized
Dec 24 01:39:35 homeassistant kernel: Bluetooth: MGMT ver 1.22
Dec 24 01:39:14 homeassistant kernel: Bluetooth: RFCOMM TTY layer initialized
Dec 24 01:39:14 homeassistant kernel: Bluetooth: RFCOMM socket layer initialized
Dec 24 01:39:14 homeassistant kernel: Bluetooth: RFCOMM ver 1.11
Dec 24 01:43:30 homeassistant kernel: Bluetooth: hci0: unexpected event for opcode 0x2005
Dec 24 01:43:41 homeassistant kernel: Bluetooth: hci0: unexpected event for opcode 0x2005
