Bluetooth on Debian not working with local VLC
This is my first post here, so if I need to do something different let me know. I have read the instructions but may have missed something on posting.
Here is my problem. I have a Bluetooth speaker connected to a Toshiba laptop running Debian 10 with HA. Everything works great but I am trying to use the Bluetooth speaker as a media player using Local VLC on HA and the Bluetooth speaker does not show up in Local VLC on HA. I have spent several hours looking for a solution but other than Mark Lewis’ blog (https://marklewis.blog/2021/02/25/home-assistant-bluetooth-speaker/) I can’t find anything.
On another note that is related, I have not been able to complete Mark’s instructions because I can’t figure out how to open the console on my laptop.
Please point me in the right direction.
Thanks!!
What do you see on the screen of your laptop?
The desktop only.
Ctrl-alt-f1.
Or use the menu to start a terminal.
That worked to get the Bluetooth working on the laptop I was not sure if it would.
It still does not work in home assistant. I will keep checking.
In the local VLC log I get:
[00007f27fe862d40] dbus interface error: Failed to connect to the D-Bus session daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
[00007f27fe862d40] main interface error: no suitable interface module
[00007f27feae49b0] main libvlc error: interface “dbus,none” initialization failed
[00007f27fa398460] main interface error: no suitable interface module
[00007f27feae49b0] main libvlc error: interface “globalhotkeys,none” initialization failed
[00007f27fe89a790] main playlist: playlist is empty
[00007f27fe86f160] [http] lua interface: Lua HTTP interface
[00007f27fe862e90] [telnet] lua interface: Listening on host “telnet://:4212”.
And when I test Entity created with:
media_player:
platform: vlc_telnet
host: 127.0.0.1
password: telnet password
I get this error in In the local VLC log:
[00007f27f9eb3c10] main decoder error: failed to create audio output
[00007f27fe893a30] vlcpulse audio output error: stream connection failure: No such entity
Repeated many times.
I am still learning. I have only been using HA for about two months.
