Bluetooth Proxy, Pax Calima Esp32
Hello I need help as I cannot find the answer anywhere.
I have Pax Calima integration from Hacs for 3 Pax Calima Fans.
I also have an esp32 generic wroom 2 that I uploaded with a bluetooth proxy from esphome in which I added a button for restart in esphome and some sensors for the board.
My problem is that the first time it worked almost flawless to connect to the fans but now for some reason it acts up. The reason I added the restart button the esp is so I can have access again.
I try to press the boost button for example and it does not work. It show the info on it like it should work but it does not. the only way I can access it again is if I start the esp.
I tried 3 esp boards all act the same. I tried messing with the bluetooth proxy, still the same I do not have any idea how do solve it if someone can help.
I want to be able to make automation for example I have an aqara sensor in the bathroom and when it rises over 50% both of the fans to start on boost mode or in the toilet I have a presence sensor if someone is there for the boost button to start. I am not able to do that because they do not respond properly.
Ask the author for help.
I wrote on github. But I cannot figure out if its from the bluetooth proxy or pax calima integration. He said he has no insight into bluetooth proxy.
