Bluetooth tracker error after 0.51 update
Bluetooth tracker not working after 0.51 update.
Error
2017-08-13 13:28:22 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform bluetooth_tracker
File “/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/init.py”, line 160, in async_setup_platform
disc_info)
File “/usr/lib/python3.6/asyncio/futures.py”, line 331, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.6/asyncio/tasks.py”, line 244, in _wakeup
future.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 244, in result
raise self._exception
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 55, in run
File “/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py”, line 32, in setup_scanner
import bluetooth
File “/usr/lib/python3.6/site-packages/bluetooth/init.py”, line 45, in
from bluetooth.bluez import *
File “/usr/lib/python3.6/site-packages/bluetooth/bluez.py”, line 10, in
import bluetooth._bluetooth as _bt
ImportError: Error loading shared library libbluetooth.so.3: No such file or directory (needed by /usr/lib/python3.6/site-packages/bluetooth/_bluetooth.cpython-36m-arm-linux-gnueabihf.so)
2017-08-13 13:28:28 WARNING (MainThread) [homeassistant.components.remote] Setup of platform harmony is taking over 10 seconds.
Having the same issue. Any suggestions? :slight_smile:
Same here had updated to 0.51.0 and was waiting for 0.51.1 update to see if it was fixed but still the same errors after update to 0.51.1…
2017-08-13 13:12:47 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform bluetooth_tracker Traceback (most recent call last): File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/__init__.py", line 160, in async_setup_platform disc_info) File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__ yield self # This tells Task to wait for completion. File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup future.result() File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result raise self._exception File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py", line 32, in setup_scanner import bluetooth File "/usr/lib/python3.6/site-packages/bluetooth/__init__.py", line 45, in <module> from bluetooth.bluez import * File "/usr/lib/python3.6/site-packages/bluetooth/bluez.py", line 10, in <module> import bluetooth._bluetooth as _bt ImportError: Error loading shared library libbluetooth.so.3: No such file or directory (needed by /usr/lib/python3.6/site-packages/bluetooth/_bluetooth.cpython-36m-arm-linux-gnueabihf.so)
That is fix with 0.51.2 that come today
