Bluetooth X825 Bug SSD Geekworm X825-C8
Hello
I found a big problem with my bluetooth.
I summarize my equipment
RPI 4 8GO version B
Sena UD100 Bluetooth USB key
Zigbee II USB key
Zwave Gen5 USB key
Original RPI power supply
D-Link USB Hub : DUB-H7 Separate power supply.
HA version:
Home Assistant 2022.8.5
Supervisor 2022.08.3
Operating System 8.4
Interface utilisateur : 20220802.0 - latest
Addons Install:
Mqtt Broker
Zigbee2Mqtt
Zwave2Mqtt
Nginx Proxy Manager
MariaDB
So I bought a box for the RPI this one
Amazon.fr : rapsbeŕry 4 ssd
Geekworm X825-C8 (X825 V2.0) Metal Case+Power Switch+Cooling Fan Support X825 V2.0 2.5 inch SATA SSD/HDD Shield & Raspberry Pi 4 Model B & X735 Only(Not Support X825 V1.5) : Amazon.fr: Informatique
for a direct installation on a crucial 240GB SSD
I test the whole thing without installing the box, everything works without worry.
But once installed in the box and the whole fixed, the Bluetooth works but more reception of my TH Xiaomi and my nuts
I changed the USB cable, even tried a shielded cable.
Change the Bluetooth key.
Change USB HUB by another brand
Installed on the USB 2 or 3 ports ditto, Bluetooth does not receive anything.
If I remove the structure (cage) the ok everything works again …
