I have a gove bme680 sensor that I am trying to connect to a grove port of a home assistant preview edition via this documentation.
I have managed to get it working using this configuration:
packages:
Nabu Casa.Home Assistant Voice PE: github://esphome/home-assistant-voice-pe/home-assistant-voice.yaml
grove-i2c: github://esphome/home-assistant-voice-pe/modules/grove-i2c.yaml
- platform: bme680
i2c_id: grove_i2c
temperature:
name: "Bedroom Temperature"
pressure:
name: "Bedroom Air Pressure"
humidity:
name: "Bedroom Humidity"
gas_resistance:
name: "Bedroom Gas Resistance"
update_interval: 60s
I thought I’d like to use the bme68x_bsec2_i2c component instead as it provides additional sensors.
I’ve tried various configurations without success as I encounter errors around the i2c_id: grove_i2c
line. Here is one version:
bme68x_bsec2_i2c:
address: 0x76
model: bme680
operating_age: 28d
sample_rate: LP
supply_voltage: 3.3V
- platform: bme68x_bsec2
i2c_id: grove_i2c
temperature:
pressure:
humidity:
iaq:
co2_equivalent:
name: "Bedroom CO2 Equivalent"
breath_voc_equivalent:
name: "Bedroom Breath VOC Equivalent"
I am not sure where the i2c_id: grove_i2c
line should go.
If I place it in the bme68x_bsec2_i2c: block I get an error This feature is only available with frameworks ['arduino'].
If I place it in the sensor block I get this error [i2c_id] is an invalid option for [sensor.bme68x_bsec2]. Please check the indentation.
Can I use the the bme68x_bsec2
component with the HA Voice PE? Or am I barking up the wrong tree?
TIA.
