Boolian usage.. ( which automation are using this boolean )
It would be nice to be able to see Boolean affiliations, or in which automations or devices/entities have to do with them. A bit like you can see where a device is used, or which automations.
You can. If you have the input_boolean popup open in the UI, there is an option for “Related” under the three dot menu.
