Bosch Cookit & Wash&Dry (Home Connect)
There is an Home Connect integration wich im using for my Coffee Machine, now i have a Cookit from bosch and this seems not to work right now. Would be nice to see this integrated too :slight_smile:
If you need any Information i will try to provide it :slight_smile:
Bosch Wash&Dry not working too :confused:
Here is another cookit user. It seems that the integration is authenticated without problems but i donโ€™t see any device in the integration.
the log states
[homeassistant.components.home_connect.api] Appliance type CookProcessor not implemented
:weary:
Here is another Cookit user. I added Cookit locally to my HA instance a few weeks ago - yesterday I tested a few more things and created a PR:
Unfortunately, the device can only be switched on/off and the current operational status (inactive/ready/run/pause/actionrequiered/โ€ฆ) can be read out. Programs (and thus hopefully also duration and remaining time) are to be enabled in the Cookit API in 2022.
you are my personal hero :slightly_smiling_face: iยดm hoping that bosch open its api even more, they are very costumer based at the moment, it takes a while for many things but they are doing what the community needs. many companies should hear more at their customers :slightly_smiling_face:
Nice, i also tried to optimize the cookit integration but i dont know nothing about the git and pull thing. so here are my main parts of my โ€œintegrationโ€. Whitin an automatic programm you can see a litle progress but without a complete api it is only a workaround.
class DeviceWithCookprocessor(HomeConnectDevice):
    """Device with programs."""
    PROGRAMS = []
    def get_programs_available(self):
        """Get the available programs."""
        return self.PROGRAMS
    def get_program_switches(self):
        """Get a dictionary with info about program switches.
        There will be one switch for each program.
        programs = self.get_programs_available()
        return [{ATTR_DEVICE: self, "program_name": p["name"]} for p in programs]
    def get_program_sensors(self):
        """Get a dictionary with info about program sensors.
        There will be one of the four types of sensors for each
        device.
        sensors = {
            "Current Step Remaining Time": (TIME_SECONDS, "mdi:camera-timer", None, 1),
            "Current StepNumber": (TIME_SECONDS, "mdi:foot-print", None, 1),
            "Program Progress": (PERCENTAGE, "mdi:progress-clock", None, 1),
        return [
                ATTR_DEVICE: self,
                ATTR_DESC: k,
                ATTR_UNIT: unit,
                ATTR_KEY: "BSH.Common.Option.{}".format(k.replace(" ", "")),
                ATTR_ICON: icon,
                ATTR_DEVICE_CLASS: device_class,
                ATTR_SIGN: sign,
            for k, (unit, icon, device_class, sign) in sensors.items()
class CookProcessor(
    DeviceWithOpState,
    DeviceWithCookprocessor,
    """CookProcessor class."""
    PROGRAMS = [
        {"name": "CookProcessor.Program.ManualProgram"},
        {"name": "BSH.Common.Program.GuidedProgram"},
        {"name": "BSH.Common.Program.AutomaticProgram"},
    def get_entity_info(self):
        """Get a dictionary with infos about the associated entities."""
        op_state_sensor = self.get_opstate_sensor()
        program_switches = self.get_program_switches()
        program_sensors = self.get_program_sensors()
        return {
            "switch": program_switches,
            "sensor": program_sensors + op_state_sensor,
Sorry to ask, but If I want to try your implementation of the api, I just copy it to home connect/api.py ?
