Bosch oven card
Do you have a Bosch oven with Home Connect capabilities?
Then this card is for you!
It has the following features:
  • Auto-detects oven entities from a single device picker — no per-entity wiring.
  • Optional oven photo — set image_url to a picture of your oven; otherwise a clean built-in oven icon is shown.
  • Visual controls: power switch, program selector, target temperature slider, child lock, start / pause / resume / stop buttons.
  • Door state indicator (with a red pill in the header when the door is open).
  • Configurable sensor tiles — pick any subset of operation state, remaining time, progress, current cavity temperature, etc.
  • Visual editor — set everything from the Lovelace UI.
It works with the native Home Connect integration, as well as Home Connect Local.
loryanstrant/ha-home-connect-oven-card: A Home Assistant card for Home Connect ovens (Bosch & others)
is it local? or require cloud polling?
As I said, it works with the native Home Connect integration, as well as Home Connect Local.
Therefore, both.
