Offler
March 16, 2025, 2:24pm
1
Edit: It does seem that the alarm does not support channel 16. Use 15 instead and restart Z2M, and factory reset Twinguard.
Just received the smoke detector and powered it on, read the install instructions on Z2M devices list and got this message when attempted to use Install Code:
[2025-03-16 14:53:23] info: zh:controller: Install code was adjusted for reason ‘missing CRC’.
It was reported and resolved about a month ago:
opened 06:20PM - 18 Jan 25 UTC
closed 07:52PM - 10 Feb 25 UTC
problem
### What happened?
I detected after updating to version 2.0.0, the install code… seems not longer working for Bosch Twinguard.
I have several Bosch Twinguards in my Zigbee Network. It was possible to connect them with the old version 1.42 without problem. Some days ago I updated to version 2.0.0. Today I wanted to connect a new Bosch Twinguard,. But it's not possible. I also tried to reconnect another Bosch Twinguard, which was already in my network before. Also here I can't get a connection with the version 2.0.0.
So I think there is something wrong with the install code "adjustment" which was included with the install code fix?
I get following messages in the log:
2025-01-18 18:56:50] info: zh:controller: Install code was adjusted for reason 'missing CRC'.
[2025-01-18 18:56:50] info: zh:controller: Adding install code for 0x000D6F00191051B7.
[2025-01-18 18:56:50] info: z2m: Successfully added new install code
[2025-01-18 18:58:11] error: zh:controller: Interview failed for '0x000d6f00191051b7 with error 'Error: Interview failed because can not get node descriptor ('0x000d6f00191051b7')'
So it seems, that the Install code will be "adjusted", but it will be not successful to connect the device.
The Bosch Twinguard have a 91-digit install code.
### What did you expect to happen?
It should work like already in the previous versions
### How to reproduce it (minimal and precise)
Everytime when I try to connect a Bosch Twinguard with 91-digit install code at the frontend with "tools->add install code"
### Zigbee2MQTT version
2.0.0
### Adapter firmware version
20210708
### Adapter
zstack
### Setup
Home Assistant Core 2025.1.4, Pi4, SONOFF ZBDongle-P
### Debug log
_No response_
Official Zigbee2MQTT Home Assistant add-on
committed 08:46PM - 10 Feb 25 UTC
Zigbee2MQTT version
2.1.3 commit: unknown
Coordinator type
EmberZNet
Coordinator revision
7.4.4 [GA]
Frontend version
0.9.4
zigbee-herdsman-converters version
23.2.0
zigbee-herdsman version
3.2.7
I am trying to pair it via Sonoff ZBDongle-E.
Given the history on Github, I would assume the issue is resolved, no idea what is wrong.
