Bricked SkyConnect?
I think I bricked my SkyConnect. Many months ago I believe I flashed Yellow firmware to my SkyConnect perhaps at the wrong baud rate and it has been non-responsive since then.
Is there any hope of getting it up and running again?
I’ve tried flashing from the web, Home Assistant, and universal-silabs-flasher. It seems like no connection to the device can be established, but it does show up in my serial devices.
universal-silabs-flasher --device /dev/ttyUSB0 -vvv flash --firmware NabuCasa_SkyConnect_EZSP_v7.1.1.0_ncp-uart-hw_115200.gbl
2024-01-11 22:59:59.904 nano asyncio DEBUG Using selector: EpollSelector
2024-01-11 22:59:59.904 nano universal_silabs_flasher.flasher INFO Probing ApplicationType.GECKO_BOOTLOADER at 115200 baud
2024-01-11 22:59:59.905 nano zigpy.serial DEBUG Opening a serial connection to '/dev/ttyUSB0' (115200 baudrate)
2024-01-11 22:59:59.908 nano universal_silabs_flasher.common DEBUG Connection made: SerialTransport(<_UnixSelectorEventLoop running=True closed=False debug=False>, <universal_silabs_flasher.gecko_bootloader.GeckoBootloaderProtocol object at 0x7ff008402730>, Serial<id=0x7ff008402460, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False))
2024-01-11 22:59:59.908 nano universal_silabs_flasher.common DEBUG Sending data b'\n'
2024-01-11 22:59:59.908 nano universal_silabs_flasher.common DEBUG Sending data b'3'
2024-01-11 23:00:01.917 nano universal_silabs_flasher.flasher INFO Probing ApplicationType.CPC at 460800 baud
2024-01-11 23:00:01.918 nano zigpy.serial DEBUG Opening a serial connection to '/dev/ttyUSB0' (460800 baudrate)
2024-01-11 23:00:01.921 nano universal_silabs_flasher.common DEBUG Connection made: SerialTransport(<_UnixSelectorEventLoop running=True closed=False debug=False>, <universal_silabs_flasher.cpc.CPCProtocol object at 0x7ff008402850>, Serial<id=0x7ff008402820, open=True>(port='/dev/ttyUSB0', baudrate=460800, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False))
2024-01-11 23:00:01.922 nano universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-01-11 23:00:01.923 nano universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-01-11 23:00:02.924 nano universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 1 of 4)
2024-01-11 23:00:03.025 nano universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-01-11 23:00:03.026 nano universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-01-11 23:00:04.028 nano universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 2 of 4)
2024-01-11 23:00:04.129 nano universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-01-11 23:00:04.130 nano universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-01-11 23:00:05.131 nano universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 3 of 4)
2024-01-11 23:00:05.232 nano universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-01-11 23:00:05.232 nano universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-01-11 23:00:06.233 nano universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 4 of 4)
2024-01-11 23:00:06.240 nano universal_silabs_flasher.flasher INFO Probing ApplicationType.CPC at 115200 baud
2024-01-11 23:00:06.241 nano zigpy.serial DEBUG Opening a serial connection to '/dev/ttyUSB0' (115200 baudrate)
2024-01-11 23:00:06.245 nano universal_silabs_flasher.common DEBUG Connection made: SerialTransport(<_UnixSelectorEventLoop running=True closed=False debug=False>, <universal_silabs_flasher.cpc.CPCProtocol object at 0x7ff008402790>, Serial<id=0x7ff0084027f0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False))
2024-01-11 23:00:06.245 nano universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-01-11 23:00:06.246 nano universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-01-11 23:00:07.247 nano universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 1 of 4)
2024-01-11 23:00:07.348 nano universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-01-11 23:00:07.349 nano universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-01-11 23:00:08.351 nano universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 2 of 4)
2024-01-11 23:00:08.452 nano universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-01-11 23:00:08.453 nano universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-01-11 23:00:09.455 nano universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 3 of 4)
2024-01-11 23:00:09.555 nano universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-01-11 23:00:09.556 nano universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-01-11 23:00:10.558 nano universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 4 of 4)
2024-01-11 23:00:10.565 nano universal_silabs_flasher.flasher INFO Probing ApplicationType.CPC at 230400 baud
2024-01-11 23:00:10.566 nano zigpy.serial DEBUG Opening a serial connection to '/dev/ttyUSB0' (230400 baudrate)
2024-01-11 23:00:10.569 nano universal_silabs_flasher.common DEBUG Connection made: SerialTransport(<_UnixSelectorEventLoop running=True closed=False debug=False>, <universal_silabs_flasher.cpc.CPCProtocol object at 0x7ff008402880>, Serial<id=0x7ff0084027c0, open=True>(port='/dev/ttyUSB0', baudrate=230400, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False))
2024-01-11 23:00:10.570 nano universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-01-11 23:00:10.570 nano universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-01-11 23:00:11.572 nano universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 1 of 4)
2024-01-11 23:00:11.673 nano universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-01-11 23:00:11.674 nano universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-01-11 23:00:12.676 nano universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 2 of 4)
2024-01-11 23:00:12.776 nano universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-01-11 23:00:12.777 nano universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-01-11 23:00:13.778 nano universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 3 of 4)
2024-01-11 23:00:13.879 nano universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-01-11 23:00:13.880 nano universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-01-11 23:00:14.882 nano universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 4 of 4)
2024-01-11 23:00:14.890 nano universal_silabs_flasher.flasher INFO Probing ApplicationType.EZSP at 115200 baud
2024-01-11 23:00:14.891 nano zigpy.serial DEBUG Opening a serial connection to '/dev/ttyUSB0' (115200 baudrate)
2024-01-11 23:00:14.896 nano bellows.ezsp DEBUG Resetting EZSP
2024-01-11 23:00:14.896 nano bellows.uart DEBUG Resetting ASH
2024-01-11 23:00:14.896 nano bellows.uart DEBUG Sending: b'1ac038bc7e'
2024-01-11 23:00:19.899 nano universal_silabs_flasher.flasher INFO Probing ApplicationType.SPINEL at 460800 baud
2024-01-11 23:00:19.906 nano zigpy.serial DEBUG Opening a serial connection to '/dev/ttyUSB0' (460800 baudrate)
2024-01-11 23:00:19.909 nano bellows.uart DEBUG Connection lost: None
2024-01-11 23:00:19.909 nano bellows.uart DEBUG Closed serial connection
2024-01-11 23:00:19.909 nano universal_silabs_flasher.common DEBUG Connection made: SerialTransport(<_UnixSelectorEventLoop running=True closed=False debug=False>, <universal_silabs_flasher.spinel.SpinelProtocol object at 0x7ff008402730>, Serial<id=0x7ff008402b50, open=True>(port='/dev/ttyUSB0', baudrate=460800, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False))
2024-01-11 23:00:19.910 nano universal_silabs_flasher.spinel DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2024-01-11 23:00:19.911 nano universal_silabs_flasher.common DEBUG Sending data b'~\x83\x02\x02\xe65~'
2024-01-11 23:00:20.912 nano universal_silabs_flasher.spinel DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 1 of 4)
2024-01-11 23:00:21.013 nano universal_silabs_flasher.spinel DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2024-01-11 23:00:21.014 nano universal_silabs_flasher.common DEBUG Sending data b'~\x83\x02\x02\xe65~'
2024-01-11 23:00:22.016 nano universal_silabs_flasher.spinel DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 2 of 4)
2024-01-11 23:00:22.117 nano universal_silabs_flasher.spinel DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2024-01-11 23:00:22.118 nano universal_silabs_flasher.common DEBUG Sending data b'~\x83\x02\x02\xe65~'
2024-01-11 23:00:23.119 nano universal_silabs_flasher.spinel DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 3 of 4)
2024-01-11 23:00:23.220 nano universal_silabs_flasher.spinel DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2024-01-11 23:00:23.221 nano universal_silabs_flasher.common DEBUG Sending data b'~\x83\x02\x02\xe65~'
2024-01-11 23:00:24.223 nano universal_silabs_flasher.spinel DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 4 of 4)
Error: Failed to probe running application type
@mlacayo Hello, were you able to solve the problem? I am experiencing the same error message.
Unfortunately not.
