Hello Everyone,
I’m new to home assistant and have VERY limited skills coding. I thought I had my automation setup correctly but for whatever reason when I go into “Traces” it seems the automation is starting halfway through the process and skipping the actual trigger and just simply turning the lights on and off with no automation. Any ideas as to what I did wrong?
The automation is so that when one, or both, lamps are set to 100% brightness to automatically turn on some additional rarely used lights in the room… 99% and below, turn those lights off.
alias: Master Bedroom Couch Lights On
description: >-
This automatically turns the couch lights on if the lamps are turned to 100%
brightness
triggers:
- trigger: state
entity_id:
- light.katies_lamp
- light.michaels_lamp
attribute: brightness
to: "100"
conditions:
- condition: time
after: "08:00:00"
before: "21:00:00"
weekday:
- mon
- tue
- wed
- thu
- fri
actions:
- type: turn_on
device_id: d788825b906be264c428541e0e3e318c
entity_id: 854e6bb3dc62917063412c9ef9f658c9
domain: light
brightness_pct: 100
- type: turn_on
device_id: de64b34c5f5724c3586881fa123754b4
entity_id: 08e8ba9ab43b2101909cdee9aeae5f70
domain: light
brightness_pct: 100
mode: single
Any advice would be greatly appreciated! LOVING home assistant so far and just getting started!
