Hello everyone!
I tried to integrate light device to HA. But I couldn’t add brightness level to my platform like in this example Example Light Platform. Even if I add brightness method to my class, then in the UI the “Effect” is invisible - when I press it, it becomes visible. But this “Effect” doesn’t allow change brightness.
Could someone help me to add brightness to my class?
Brightness doesn’t work even for minimal structure of light platform, without my custom device protocol. For example, file /custom_components/light/example_light.py
is:
from homeassistant.components.light import ATTR_BRIGHTNESS, Light
def setup_platform(hass, config, add_devices, discovery_info=None):
add_devices([MyExampleLight()])
class MyExampleLight(Light):
def __init__(self,):
self._name = "My example light"
self._state = None
self._brightness = None
@property
def name(self):
return self._name
@property
def brightness(self):
return self._brightness
@property
def is_on(self):
return self._state
def turn_on(self, **kwargs):
self._brightness = kwargs.get(ATTR_BRIGHTNESS, 255)
self._state = True
def turn_off(self, **kwargs):
self._state = False
def update(self):
pass
And configuration.yaml
is:
light:
- platform: example_light
Thank you in advance.
Roman
