So I have a setup that is using TP link bulbs. They work fine for everything but what I want to do is after sunset when a scene is selected have all the bulbs dim down to half of what they are currently at. I think I have this all set up correctly but for some reason the percent part is not working the way I think it should be and I could be wrong too. So my understanding is if I have this set to -50 It should look at the current brightness and reduce it by half. I have a master dimmer helper that is what sets all the bulbs. What is interesting to me and why I think its not working is if it is at 100 it will dim to 50… But if its at 10 it will go to 0 instead of 5. Or if its at 80 it goes to 30. I would expect it to go to 40 if it started at 80 so maybe im wrong in how this is supposed to work. Let me know what you all think.
alias: Dim After Sunset when Scene is selected
description: ''
triggers:
- trigger: event
event_type: call_service
event_data:
domain: scene
service: turn_on
enabled: true
context:
user_id:
- blablabla
conditions:
- condition: sun
after: sunset
after_offset:
hours: 0
minutes: 35
seconds: 0
actions:
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- action: light.turn_on
metadata: {}
entity_id: light.master_dimmer
transition: 2
brightness_step_pct: -50
mode: single
So It should activate a scene… wait 5 second for all the bulbs to get to where they should be then apply the -50% and do that over 2 seconds. I have played with delays and that seems to have no effect. So long as a scene is over 50% brightness it does not dim to 0 but if its below 50% it will dim to 0.
