Broadlink does not work anymore
Hello, I try to configure my Broadlink Mini but it does not work anymore. I created a simple button that worked well, then I used the Broadlink Manager application to register my remotes, I added several switches but it does not work anymore. The Broadlink Manager application works well for sending codes and my device responds well. I erased all my switches to keep only 1 for debugging to be easier. I looked at my configurations several times, I erase restart and restart the broadlink. I even added the logger
logger:
  logs:
#    homeassistant.components.ecovacs: debug
#    homeassistant.components.vacuum.ecovacs: debug
#    sucks: debug
    homeassistant.components.broadlink: debug
  - platform: broadlink
    host: 172.16.82.60
    mac: 'b4:43:0d:f9:1c:47'
    friendly_name: 'rm-mini'
    switches:
      tv_haier_power:
        friendly_name: "tv haier power"
        command_on: 'jgbyaaabjzyqfravedctfbaverqqfg8wedkrobevedkrobe5etgroraverqqfra5erqqfhavebuqore5dzorfba5edoroba6eqafgaabjusraaxnaaemsxeadqu='
        command_off: 'jgbyaaabjzyqfravedctfbaverqqfg8wedkrobevedkrobe5etgroraverqqfra5erqqfhavebuqore5dzorfba5edoroba6eqafgaabjusraaxnaaemsxeadqu='
      tv_haier_input:
        friendly_name: "tv haier input"
        command_on: 'jgbgaaabjzurfbevdzoqfraveruqfbavedoqoravedoqora6dzorobe5edkqfra6ebuqfg8vebuqfreuedoqfra5edorobe5eaafjaabjksqaaxaaaelsxaadfoaasvmeaanbqaaaaaaaaaa'
        command_off: 'jgbgaaabjzurfbevdzoqfraveruqfbavedoqoravedoqora6dzorobe5edkqfra6ebuqfg8vebuqfreuedoqfra5edorobe5eaafjaabjksqaaxaaaelsxaadfoaasvmeaanbqaaaaaaaaaa'
      tv_haier_vol_up:
        friendly_name: "tv haier volume up"
        command_on: 'jgbiaaabjzurfravetgrfbeuerqrfravedkrobevedkrobe5etgroravetgrfbeuerqrfbevebuqoreuetkqore4etkroba6eaanbq=='
        command_off: 'jgbiaaabjzurfravetgrfbeuerqrfravedkrobevedkrobe5etgroravetgrfbeuerqrfbevebuqoreuetkqore4etkroba6eaanbq=='
      tv_haier_vol_down:
        friendly_name: "tv haier volume down"
        command_on: 'jgbgaaabjzyrfbeuetgrfbeuebuqfhavetgrobevedkroba6etgrnhm5edkrfravebuqfraverqrfbeuedoqora5etkrobe5eaafjaabjksraaxxaaemsxeadfgaaszleqanbqaaaaaaaaaa'
        command_off: 'jgbgaaabjzyrfbeuetgrfbeuebuqfhavetgrobevedkroba6etgrnhm5edkrfravebuqfraverqrfbeuedoqora5etkrobe5eaafjaabjksraaxxaaemsxeadfgaaszleqanbqaaaaaaaaaa'
      tv_haier_vol_mute:
        friendly_name: "tv haier volume mute"
        command_on: 'jgbyaaabjpuqfreuedkrfbeuerqqfhavedkrobevdzorobe5etgroba6etgrfbeuebyqfra5erqqfreuetkqore4etkrfbe4eaafjqabjuwqaaxzaaemsheadqu='
        command_off: 'jgbyaaabjpuqfreuedkrfbeuerqqfhavedkrobevdzorobe5etgroba6etgrfbeuebyqfra5erqqfreuetkqore4etkrfbe4eaafjqabjuwqaaxzaaemsheadqu='
      tv_haier_arrow_up:
        friendly_name: "tv haier cross up"
        command_on: 'jgbyaaabjzurfbeuedorfbeuerqqfreuetkqoreuetgrore4etkrobeuebuqfreuerqqfha5erqqore5etgrora5etgqfhe4eqafjaabjusraaxyaaensheadqu='
        command_off: 'jgbyaaabjzurfbeuedorfbeuerqqfreuetkqoreuetgrore4etkrobeuebuqfreuerqqfha5erqqore5etgrora5etgqfhe4eqafjaabjusraaxyaaensheadqu='
      tv_haier_arrow_down:
        friendly_name: "tv haier cross down"
        command_on: 'jgbgaaabj5qrfbavedkrfravebuqfreuetgqohavedkrora5etgqohe4erqqfreueruqfra5erqqfre5edkrobe5etgqfre5eqafiwabjuwraaxyaaemsxaadfkaaszkeqanbqaaaaaaaaaa'
        command_off: 'jgbgaaabj5qrfbavedkrfravebuqfreuetgqohavedkrora5etgqohe4erqqfreueruqfra5erqqfre5edkrobe5etgqfre5eqafiwabjuwraaxyaaemsxaadfkaaszkeqanbqaaaaaaaaaa'
      tv_haier_arrow_left:
        friendly_name: "tv haier cross left"
        command_on: 'jgbyaaabjzyrfbavetgrfbeueruqfravedkqorevedkrobe5edkqohe4etkqoravebuqfraveburfbawdxyqore4etkrobe5eaafjaabjksraaxyaaemsxeadqu='
        command_off: 'jgbyaaabjzyrfbavetgrfbeueruqfravedkqorevedkrobe5edkqohe4etkqoravebuqfraveburfbawdxyqore4etkrobe5eaafjaabjksraaxyaaemsxeadqu='
      tv_haier_arrow_right:
        friendly_name: "tv haier cross right"
        command_on: 'jgbyaaabjzurfbeuetkqfreuerqqfravetgroreuedkqohe4edoqoreuetgroreuerqqfreuerqroraveburoba6dzoroba6eqafiwabjksqaaxzaaelsxaadqu='
        command_off: 'jgbyaaabjzurfbeuetkqfreuerqqfravetgroreuedkqohe4edoqoreuetgroreuerqqfreuerqroraveburoba6dzoroba6eqafiwabjksqaaxzaaelsxaadqu='
      tv_haier_arrow_ok:
        friendly_name: "tv haier cross ok"
        command_on: 'jgbyaaabjzurfbavedoqfreuerqrfbeuetkqoreuetkpohe4etkrobeuerqroraverqrfba5eruqore4erqrora5etkqfra5eaafjqabjkoraaxyaaeltbeadqu='
        command_off: 'jgbyaaabjzurfbavedoqfreuerqrfbeuetkqoreuetkpohe4etkrobeuerqroraverqrfba5eruqore4erqrora5etkqfra5eaafjqabjkoraaxyaaeltbeadqu='
A few ideas:
Try to include “type”:
    host: 172.16.82.60
    type: rm_mini
  • Any complaints in the log file?
  • Any new firewall rules that block HA to connect the RM Mini?
  • Can you ping 172.16.82.60 from the HA machine?
  • Verify the correctness of the mac address
Otherwise I don’t see anything that is wrong.
