I’m having trouble finding were the Broadlink library is located.
I’m trying to use the broadlink network discovery fn. I created a PHP broadlink API & know its possible to get a list of all broadlink devices & their model# / device name.
I’m wish to create a discovery function which as 1st phase lists all Broadlink devices on the network & then hopefully create an auto setup for Broadlink devices.
PS: I’ve searched the community but no refs to NW discovery found.
I also (unfortunately) have a bunch of broadlink switches. I have found several android applications which can discover the devices, so it is doable. The best of these seems to be the Tasker plugin titled “RM Plugin lite” (or the non-lite paid version… ) the best thing about it is it has a HTTP bridge which that lets you query discovered devices and control them! The current method of having to hard code an IP and MAC address and populate friendly names etc manually is really a bit of a poor mans solution…
That is only for the RM Pro and A1 sensor. Hmm… And SP2, SP3 and MP1… I hadnt see those listed, but shame as I have SPmini (SP1) devices too.
The relevant documentation for Broadlink is https://home-assistant.io/components/switch.broadlink/ where MP1 and SP1 through SP4 is documented as requiring both hardcoded IP addresses and MAC addresses. Just having to set a DHCP reservation for all the various devices is a no go…
so basically I’m stuck with reserving the IP address in DHCP for each of the switches… and then hard coding the IPs into the configuration.yaml file for hass.io… ?
As a long time sys admin, hard coding an IP address is a big no no… always abstract… and when we know it’s fully discoverable, why create more work and require hard coding both on the DHCP server and in configuration files?
