Broadlink RM Mini 3 IR how to decrease the time it's sending the signal?
Hi there,
Is there a way to decrease the time of the broadcasting of the signal from the Broadlink rm mini 3.
When I normally press the volume up on my remote it just sends the signal ones, but when I use the switch.broadlink_send_packet_xxx_xxx_x_x (x = ip) service it looks like it’s sending the signal for 1-2 sec. leading to an increase of 14 in volume.
When you captured the IR code originally, how long did you hold the button down for?
That could be the problem, I will try to scan the code again tomorrow and see if this fixes it.
This fixed the problem thank you
