Broadlink RM mini does not work on HA 077
Hey I cannot get the broadlink RM mini to work under 0.77.3
Any solution ?
Broadlink ir code length not a multiple of XX I forget what XX is. Maybe 8. Remove all your ir codes and see if it works after that. If it does then try and find my post about the code length to fix it
Can you elaborate? Not sure I fully understand…
Even if I send empty packet rm mini will not respond to command
