Hi all,
I have the Broadlink RM Mini 3 which is getting detecting fine by HA, however I’ve been unable to get any IR codes I put into my yaml configuration to actually work.
When starting HA:
2018-04-29 10:38:27 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform broadlink
File "/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/entity_platform.py", line 82, in async_setup
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for
return fut.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/switch/broadlink.py", line 158, in setup_platform
device_config.get(CONF_COMMAND_OFF)
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/switch/broadlink.py", line 194, in __init__
self._command_off = b64decode(command_off) if command_off else None
File "/usr/lib/python3.5/base64.py", line 88, in b64decode
return binascii.a2b_base64(s)
binascii.Error: Incorrect padding
2018-04-29 10:38:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event system_log_event[L]: exception=Traceback (most recent call last):
return fut.result()
, message=Error while setting up platform broadlink, source=components/switch/broadlink.py, level=ERROR, timestamp=1524998307.006397>
My Broadlink config in configuration.yaml:
switch:
- platform: broadlink
host: 192.168.1.58
mac: '34:EA:....'
friendly_name: "RM3 mini"
type: rm_mini
update_interval: 60
switches:
ac_daikin:
command_on: "JgBQAhANDw0PDRANEAsQAANCdDgQKRANDw0PDRApEA0QDA8NEA0QKRANDyoPKg8NECkQKRAqDyoQKRANEAwPKw8MEA0QDQ8MEA0QDQ8NDw0QDQ8NECkQDBApEA0QDQ8NDyoPKw8MEA0QDQ8MEA0QDQ8MEA0QDQ8NDw0QDQ8NEAwQDQ8NECkQKg8qEAwPKw8MECoPKhAABHp0OBApEA0QDQ8MECoPDRANEAwPDRApEA0QKRAqDw0PKg8rDyoPKg8qDw0QDRApEA0PDBANEA0PDQ8NEA0PDQ8NEA0PDRApEAwQDQ8NEA0PKg8NEA0PDRApECoPDBANECkQDRApEA0PKg8qDw0QDQ8NDw0QKRANDyoQKRANECkQDBApEAAEe3Q3ECoPDRANEAwPKw8MEA0QDQ8MECoPDRApECoPDRAqDyoQKRApECoPDBANECkQDQ8NDw0QDQ8NEAwQDQ8NEA0PDQ8NEA0QDA8NEA0QDA8NEA0PDQ8NEA0PKhANDwwQKRANEA0QKRApECkQDQ8qDw0QDQ8NEAwQDQ8NEA0PDQ8NEA0PDQ8NEA0QDA8qECkQDQ8NEA0PDQ8NEA0QDA8NEA0QDA8NEA0QDA8NEA0PDRAMEA0PDRAqDyoQDA8NEA0PDRAMEA0PDRANDw0PDRAqDyoQDBAMEA0PDRAMEA0PDRANDw0PDRANEAwPDRANEA0ODRANECkQDQ8MEA0QDQ8MECoPKhAMEA0QDQ8MEA0QDQ8MEA0QDQ8NDw0QDQ8NEAwQDQ8NECkQKg8qECkQKRAMECkQKRAADQUAAAAAAAAAAA=="
command_off: "JgBQAhANDw0PDRANEAsQAANCdDgQKRANDwwQDRApEA0QDA8NEA0QKRANDyoPKg8NECkQKRAqDyoQKRANDw0PKw4NEA0QDQ8MEA0QDQ8NDw0QDBANECkQDBApEA0QDQ8NDyoPKw4NEA0QDQ8MEA0QDQ8MEA0QDQ8NDw0QDBANEAwQDBANECkQKRAqDw0PKw4NECoPKhAABHp0OBApEA0QDQ8MECoPDRANEAsQDRApEA0QKRAqDw0PKg8rDyoPKg8qDw0QDQ8qEA0PDBANEAwQDQ8NEAwQDQ8NEAwQDRApEAwQDQ8NEA0PKg8NEAwQKg8qECkQDRALECoQDBAqDw0QKg8qDw0PDRANDw0PKg8rDyoPKg8NECkQDRApEAAEe3Q3ECoPDRAMDw4PKhAMDw4ODg8NDysPDRApECoQCxAqECkQKRApECoQDBANECkQDA8ODg4PDg4ODw0QDQ8MDw4PDg8NDg4PDg8NEAwPDg8NDw4ODg8NDw4OKw8NEAwPKw8NEAwQKRApECoPDRAqDw0QDQ4ODg4PDg8MDw4PDg8NDg4PDg8NDg4PDg8qECkQDQ8MDw4PDg8NDg4PDg8NDw0PDg8NDw4ODg8NDw4ODg4ODw4PDQ4rDyoQDQ8NDw4ODg8NDw4PDQ4ODw4PDQ4sDisPDQ8NDw4PDQ4ODw4PDQ4ODw4PDQ4ODw4PDQ8NDw4PDQ8ODisPDQ8ODg4PDQ8ODisPKhANDwwPDg8ODg4ODg8ODg4PDQ8NDw4PDg4NDw4PDg8MDysPKhApECkQKg8NECkQKg8ADQUAAAAAAAAAAA=="
host: 192.168.1.32
mac: '34:EA...'
friendly_name: "Matt's Desk Light"
type: sp3
update_interval: 60
host: 192.168.1.26
mac: '34:EA....'
type: sp3
friendly_name: "Matt's Bed Lamp"
update_interval: 60
host: 192.168.1.25
mac: '34:e..... '
type: sp3
friendly_name: "Plug#3"
update_interval: 60
Those IR codes are exactly what I get from the HA logs:
2018-04-29 10:37:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_call_id=1975829520-10, service_data=, domain=switch, service=broadlink_learn_command_192_168_1_58>
2018-04-29 10:37:07 INFO (MainThread) [homeassistant.components.switch.broadlink] Press the key you want Home Assistant to learn
2018-04-29 10:37:11 INFO (MainThread) [homeassistant.components.switch.broadlink] Received packet is: JgBQAhANDw0PDRANEAsQAANCdDgQKRANDwwQDRApEA0QDA8NEA0QKRANDyoPKg8NECkQKRAqDyoQKRANDw0PKw4NEA0QDQ8MEA0QDQ8NDw0QDBANECkQDBApEA0QDQ8NDyoPKw4NEA0QDQ8MEA0QDQ8MEA0QDQ8NDw0QDBANEAwQDBANECkQKRAqDw0PKw4NECoPKhAABHp0OBApEA0QDQ8MECoPDRANEAsQDRApEA0QKRAqDw0PKg8rDyoPKg8qDw0QDQ8qEA0PDBANEAwQDQ8NEAwQDQ8NEAwQDRApEAwQDQ8NEA0PKg8NEAwQKg8qECkQDRALECoQDBAqDw0QKg8qDw0PDRANDw0PKg8rDyoPKg8NECkQDRApEAAEe3Q3ECoPDRAMDw4PKhAMDw4ODg8NDysPDRApECoQCxAqECkQKRApECoQDBANECkQDA8ODg4PDg4ODw0QDQ8MDw4PDg8NDg4PDg8NEAwPDg8NDw4ODg8NDw4OKw8NEAwPKw8NEAwQKRApECoPDRAqDw0QDQ4ODg4PDg8MDw4PDg8NDg4PDg8NDg4PDg8qECkQDQ8MDw4PDg8NDg4PDg8NDw0PDg8NDw4ODg8NDw4ODg4ODw4PDQ4rDyoQDQ8NDw4ODg8NDw4PDQ4ODw4PDQ4sDisPDQ8NDw4PDQ4ODw4PDQ4ODw4PDQ4ODw4PDQ8NDw4PDQ8ODisPDQ8ODg4PDQ8ODisPKhANDwwPDg8ODg4ODg8ODg4PDQ8NDw4PDg4NDw4PDg8MDysPKhApECkQKg8NECkQKg8ADQUAAAAAAAAAAA==
2018-04-29 10:37:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1975829520-10>
2018-04-29 10:37:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_call_id=1975829520-11, service_data=message=Received packet is: JgBQAhANDw0PDRANEAsQAANCdDgQKRANDwwQDRApEA0QDA8NEA0QKRANDyoPKg8NECkQKRAqDyoQKRANDw0PKw4NEA0QDQ8MEA0QDQ8NDw0QDBANECkQDBApEA0QDQ8NDyoPKw4NEA0QDQ8MEA0QDQ8MEA0QDQ8NDw0QDBANEAwQDBANECkQKRAqDw0PKw4NECoPKhAABHp0OBApEA0QDQ8MECoPDRANEAsQDRApEA0QKRAqDw0PKg8rDyoPKg8qDw0QDQ8qEA0PDBANEAwQDQ8NEAwQDQ8NEAwQDRApEAwQDQ8NEA0PKg8NEAwQKg8qECkQDRALECoQDBAqDw0QKg8qDw0PDRANDw0PKg8rDyoPKg8NECkQDRApEAAEe3Q3ECoPDRAMDw4PKhAMDw4ODg8NDysPDRApECoQCxAqECkQKRApECoQDBANECkQDA8ODg4PDg4ODw0QDQ8MDw4PDg8NDg4PDg8NEAwPDg8NDw4ODg8NDw4OKw8NEAwPKw8NEAwQKRApECoPDRAqDw0QDQ4ODg4PDg8MDw4PDg8NDg4PDg8NDg4PDg8qECkQDQ8MDw4PDg8NDg4PDg8NDw0PDg8NDw4ODg8NDw4ODg4ODw4PDQ4rDyoQDQ8NDw4ODg8NDw4PDQ4ODw4PDQ4sDisPDQ8NDw4PDQ4ODw4PDQ4ODw4PDQ4ODw4PDQ8NDw4PDQ8ODisPDQ8ODg4PDQ8ODisPKhANDwwPDg8ODg4ODg8ODg4PDQ8NDw4PDg4NDw4PDg8MDysPKhApECkQKg8NECkQKg8ADQUAAAAAAAAAAA==, title=Broadlink switch, domain=persistent_notification, service=create>
2018-04-29 10:37:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=persistent_notification.notification_2, old_state=None, new_state=<state persistent_notification.notification_2=notifying; message=Received packet is: JgBQAhANDw0PDRANEAsQAANCdDgQKRANDwwQDRApEA0QDA8NEA0QKRANDyoPKg8NECkQKRAqDyoQKRANDw0PKw4NEA0QDQ8MEA0QDQ8NDw0QDBANECkQDBApEA0QDQ8NDyoPKw4NEA0QDQ8MEA0QDQ8MEA0QDQ8NDw0QDBANEAwQDBANECkQKRAqDw0PKw4NECoPKhAABHp0OBApEA0QDQ8MECoPDRANEAsQDRApEA0QKRAqDw0PKg8rDyoPKg8qDw0QDQ8qEA0PDBANEAwQDQ8NEAwQDQ8NEAwQDRApEAwQDQ8NEA0PKg8NEAwQKg8qECkQDRALECoQDBAqDw0QKg8qDw0PDRANDw0PKg8rDyoPKg8NECkQDRApEAAEe3Q3ECoPDRAMDw4PKhAMDw4ODg8NDysPDRApECoQCxAqECkQKRApECoQDBANECkQDA8ODg4PDg4ODw0QDQ8MDw4PDg8NDg4PDg8NEAwPDg8NDw4ODg8NDw4OKw8NEAwPKw8NEAwQKRApECoPDRAqDw0QDQ4ODg4PDg8MDw4PDg8NDg4PDg8NDg4PDg8qECkQDQ8MDw4PDg8NDg4PDg8NDw0PDg8NDw4ODg8NDw4ODg4ODw4PDQ4rDyoQDQ8NDw4ODg8NDw4PDQ4ODw4PDQ4sDisPDQ8NDw4PDQ4ODw4PDQ4ODw4PDQ4ODw4PDQ8NDw4PDQ8ODisPDQ8ODg4PDQ8ODisPKhANDwwPDg8ODg4ODg8ODg4PDQ8NDw4PDg4NDw4PDg8MDysPKhApECkQKg8NECkQKg8ADQUAAAAAAAAAAA==, title=Broadlink switch @ 2018-04-29T22:37:11.226517+12:00>>
2018-04-29 10:37:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1975829520-11>
And I’m learning by calling the service here:
Any thoughts on why I can’t get this to work?
Thanks!
Matt
